Tinting Questions
Old Jun 27, 2001 | 08:59 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Tinting Questions
The summer heat is finally getting to me and I can't stand being roasted alive while the sun shines in through the t-tops. The car gets hot like an oven even when it isn't warm outside. I want to tint the t-tops, side windows and rear hatch. Here's what I need to know.
#1. I want to use the darkest tint I can find for the t-tops. I saw some 20% Gila tint at Autozone, and it was the darkest they had. It's also heat reflective. Is that just a marketing gimmick or can tint actually be heat reflective? Is that also the darkest tint available?
#2. Everybody says 3M tint is the best, but I can't find it anywhere. Where should I go? Will a tint shop stock any? Also, how much does 3M film cost? Gila costs anywhere b/w $8 and $13.
#3. Does any company make tint that specifically reduces heat and UV glare?
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
Old Jun 27, 2001 | 10:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you want your tops to not let light thru,, paint them.
If you want tinted windows,, dont use Gila,,, unless you like purple tint in a few months or you just dont care
Absolutly Nothing black colored reflects heat (tint does reject interior rotting UV though)
Silver tint would be the only way to reject sunlight heat
Any real pro tint shop uses a metalized tint film (Gila is Dyed which is why it turns purple) that holds out for a long time and will be offered with (in some cases) a lifetime warrenty (as long as you're the owner that tinted the windows)
The mind is like a parachute, it only works when its open
colton_carlson
Mar 8, 2019 12:21 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Polo Z03
Sep 10, 2015 06:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
