Wipers skipping on windsheild
Old Jul 24, 2008 | 11:25 AM
Viking's Avatar
Car: / 89 IROC /
I guess it might be from rain-X that I applied a long time ago, but how do I clean my windsheild so that my wipers do not skip across the glass in the rain? the wipers are brand new.
Old Jul 24, 2008 | 12:56 PM
Stattman's Avatar
Re: Wipers skipping on windsheild
Did you make sure that you have the right size blades?
Also Rain-X might help alot. Usually the wipers start sticking because they are new and the windshield is just dry.
Old Jul 24, 2008 | 02:44 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I would imagine two reasons.
1) The wipers will skip if they arent "lubricated" with water. My wipers do this when it starts to rain, but after a few wipes, they stop and work smooth. I too have applied rain-x a while back (maybe a year ago) but i doubt that would cause them to skip.
2) You may have installed them upside. Do they skip in both directions? ie: up AND down, or just one?
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Replacing the wiping arms will fix the issue. I think the cause of the skipping is the springs in the wipers arms are worn out.
Old Jul 24, 2008 | 03:33 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Clean the winshield real good. Try to find the white scrubby pads that say "safe for china and porcelain", they work absolutely awesome. I use them on all my glass!!!
Old Jul 26, 2008 | 12:41 PM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
i had a problem with this too. whatever wipers i used seemed to chatter and skip on the window like it was sticky or something. i bought some piaa super silicone wiper blades and it fixed the problem.. they also last a year or two. they are expensive though.
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
