Bird crap etched stain on my clear coat on hood!
Old Jul 3, 2001 | 01:18 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I have an ASCD fiberglass hood on my '87 IROC with a new paint job and clear coat. It looks great. Three birds no less crapped on it and before I could get it off it etched three stains or marks on my hood the size of a half dollar each. What can I do? I tried Macguiers wax, no luck!
Darn Birds!!! Ugh!! Good thing Emus can't fly!!
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old Jul 3, 2001 | 04:43 AM
Chuck Everly's Avatar
Phil,
Try some glazing compound. If that does not work get some polishing compound.
Old Jul 3, 2001 | 07:49 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I don't know what those birds eat but it's lethal to paint jobs. I just went through this last week on a 97 Cadillac. I'm in a body shop so I had some pro equipment.
I used 3M Perfect It Rubbing Compound, a Dewalt Buffer with Lambs wool bonnet and it made it appear much better but even then there was a trace of the outline of their "poop fest".
I'm thinking you may have to go as far as wet sanding with 1200 THEN buffing with compound and finishing with Machine Glaze and a Foam Pad.
If you lack the equipment or supplies consider going back to whoever did your paint. They may cut you some slack.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
