Side-Molding Removal....
Old Sep 17, 2008 | 07:54 PM
Shakermaker05's Avatar
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
Anyone here remove the side moldings in the quest for a cleaner appearance?? I removed mine today with a heat-gun and I can't get all the glue stains off my door panel. I was wondering if anyone had this problem and what kind of a cleaner you used to get rid of it. So far I used soap water and goo gone. That did the trick with most of it, but there still the edge lines (top and bottom) where the molding met the the visible part of the door. Any suggestions??
Old Sep 17, 2008 | 09:20 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Re: Side-Molding Removal....
I dont know about on the camaro's, but when I redid my mustang I used goo gone to get the left over adhesive off. I've also heard mean grean works on some adhesives.
GL
crrllmich
Oct 1, 2005 09:00 PM
