Firebird GROUND EFFECTS
Old Dec 4, 2008 | 02:39 PM
vargasjc's Avatar
I got a 89 firebird formula
kind of looks like these:
http://www.stevesautosales.com/89formulablue3056.jpg
Its red though
I am looking for this body kit:
http://images.highperformancepontiac...n_trans_am.jpg
I noticed its on a trans am...so my questiong is...would it fit on mine??
If yes how much would it be? (specially the front bumper)
and where could i get one
Old Dec 4, 2008 | 02:57 PM
Stephen's Avatar
Car: 87 GTA
Re: Firebird GROUND EFFECTS
That blue car isn't a kit. Its stock. And yes, it'll all bolt right o your car, with only small mounting holes needed to be drill, which will be hidden behind the fx.
But the nose doesn't use a separate fx piece. Its all one piece, so you'd just swap the nose out.
Old Dec 4, 2008 | 07:16 PM
vargasjc's Avatar
I know...the blue car is just like mine (stock)
I am looking for the red car's kit
Old Dec 4, 2008 | 07:26 PM
Stephen's Avatar
Car: 87 GTA
Sorry...I got the 2 colors switched when I typed it.
The RED car is stock. Just hit a junk yard & put those pieces on your car. Same thing applies as I said above. Stock nose, just swap your nose for that one. The fx are molded into the nose, not a separate piece.
Old Dec 4, 2008 | 08:50 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Its red though
Everyone makes it seem really easy, but if youve never installed one before, and especially if youre working outside and dont have access to a proper garage and tools, it can be tricky.
Do a search for GFX or Ground Effects "REMOVAL". Theres alot of helpful tips in there. When you get the parts, just lay them out, and trace out all the holes to understand how its mounted. Take your time, measure twice and cut/drill once.
Its not rocket science, but you have to be a little intuitive, theres ALOT of bolts. Regardless though, it is pretty much a bolt in/direct fit.
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
