88 Trans am running lights
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Is there any way to turn the two front parking lights into running lights that come on and stay on at all times when the car is started?
Car: 87 GTA
Re: 88 Trans am running lights
Are you trying to turn them into driving lights? I just flip my parking light switch on.
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
On the 90 firebirds/Trans Am's that were exported to Canada they were made to be Daytime running lights mandatory. I would see if you could get a hold of an export service manual to see how it was done.
There is a way to retrofit DRLs.
A few years ago, there was someone who made both filaments of the parking lights be on all the time so that the parking lights were super bright just like the DRLs. It would be brighter than a stock-wired thirdgen with parking lights on. Blinkers were still functional. Its a somewhat complex schematic for those not familar with electronics but not impossible. It involves transistors, resistors, and maybe relays. Radio shack has all the parts for it and i wouldn't think it would run more than $25. I was going to build the circuit but just haven't got to it yet. I got the schematic/diagram from the guy who designed the circuit, just have to find it.
Car: Pontiac Firebird Formula
Engine: 305 TBI
I have them on my 89 Formula. I bought the kit from allquality custom auto accessories. there website was bestdrls.com but it wasnt up when i order them. you have to email them. if you want that email let me know.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Check out this thread. The OP was trying the same thing for his Camaro, but should be the same for Firebird.
https://www.thirdgen.org/forums/auto...-question.html
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
My 1992 service manual has the diagrams for DRLs factory for the export, so you don't need a special export service manual, it's in the standard book. Thought about getting ahold of a canadian car to do this myself with factory parts, most of the stuff is there, just looks like you need modules and fuses, maybe a little bit of modifications being it wasn't factory. I don't know, maybe the harness isn't there and just the fuse panel part of it is.
maroe624
Apr 16, 2017 08:29 AM
