vote on this design idea...
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
Re: vote on this design idea...
i am loving all the ideas being thrown out.. but you guys are making it hard for me to decide how it should be done! now i can't decide if i like the new angle better or not..i like how i had it.. but the new way is almost kind of cool too.
i think i like the original angle better though.. i think i will stop by our local print place and see how much it would cost and if they could cut me a decal the original style but with the iroc logo in the stripe.
Car: 1988 Camaro IROC-Z
Engine: 350 5.7L V8
I think that the last two images i posted are the best, i dont think there will be any better ways to angle the stripe. So if it helps, you only have two choices lol.
Car: 84 Z28, 05 Mazda 6
Axle/Gears: 3.42 Open
I'm a big fan of that stripe, I think the first style with it meeting the way the spoiler does looks the best. I might have to pirate this one and put Z28 in the stripe. Awesome idea
Car: 87 GTA
Matching angle
Butted up stripe
In my 2 ideas, I like the butted stripe better than my first, since it "hides" the different angles between the stripe & the spoiler base (leading edge).
Engine: 350 5.7L V8
Now i see it. I can say i definitely say the butted stripe looks better. If i had to choose for my car it'd be a close call between the butted stripe and original design. Both imo look really good. Thankfully i wont have to choose, lol im going heritage stripes for my ROC.
i am not really digging how you have the bottom of the stripe getting bigger at the bottom.. it's a little weird for me. BUT, if anyone wants to take this idea and make it to suite their own taste i would LOVE to see pics. i am pretty sure that i will be doing the original stripe design with the iroc logo inside the stripe.. that one looks best imo.
Engine: 350 5.7L V8
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
interesting, but it doesn't flow with the spoiler right next to it.
Just a suggestion.....
put the back edge of the stripe on the front side of the spoiler - to the mid point, where it would be visible on the side, and then run it into the body at the matching angle. It would tie the two together.
I would keep the iroc name, as long as no other iroc is on the side of the car. Duplication can look tacky.
Running it to the bottom edge of the spoiler looks better than the other, to me
Good luck!
Good luck!
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
elle Well the lower photo describes exactly what I said above, match the rear of the stripe to the front edge of the taillights, that looks much more balanced than the first photo. Later.
Car: 1989 iroc-z
Engine: mildly built TPI 350
Transmission: 97 T56
Axle/Gears: 3.73 posi
or i think if you go with the original design, you should put the pinstripe type thing on the back end as well. it might not look as good on the car as it does in my head though.
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
i say you use the "butted up" design but leave it all the same width.
Then pull the stripe all the way to the body like in that direction and under the body line, kick it back the opposite way until it meets the body kit piece... Kinda like this ">" on the car
Engine: 350 5.7L V8
While photoshopping this design on the car, I gave the stripe the exact sideways V shape on the car and it really didnt look as good as the stripe. It killed the way the current stripe goes with the body and the V shape isnt the way to go.
Car: 88 t/a 92 rs camaro 88 firebird
Engine: 305 tbi in both
Transmission: auto camaro 5spd firebird th375
Axle/Gears: 3.73 minispool
i think the stripe should not be lower than the tail lights it looks good on the silver car but the red car it seems a little off the angle is wrong on the bottom of the stripe but i like the idea
Engine: 350 5.7L V8
Car: 85 Z28
Transmission: 5 speed
I would also bring it down to where that body line is.
This is such a cool idea cant wait to see how it turns out.
I like the stripe idea. Here's something I came up with to change it.
The other thing I didn't really like was how the bottom of the stripe ended awkwardly, and how it didn't really match the body line.
My lines are close, not exact, but you should get the idea. The bottom of the stripe would follow the black line on the bottom of the tail lights.
Car: 87 GTA
I knew it looked unfinished when I did it, but couldn't quite picture WHY.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Borg Warner T5
That stripe looks really good i think. I just bought a 91 RS recently and joined this forum. My car is all white, so ive been throwing around ideas in my head of ways to make it stand out and not be so boring lol. Im leanin more towards some side striping or for the hood, but this is a possibility now as well.
Car: 1989 iroc-z
Car: 1986 IROC-Z
I would put IROC-Z on it if I was going to do it. But thats just me, either way, its a cool idea and I like it
it would probably fit well with the stripe being wider at the bottom.. but i personally like it better with the original style stripe. i do like the idea of "iroc-z" better though.
Axle/Gears: unknown
I do not have photoshop, so please excuse this crude drawing
run the back edge of the stripe on the front of the spoiler
IROC or IROC-Z should be in the bottom of the stripe! (porportional to the stripe)
Car: 87 GTA
Car: 1989 iroc-z
haha. yea it was close to the same idea but hes sayin actually put the back end of the stipe ON the spoiler instead of just up to it. which might be a good idea.
Axle/Gears: unknown
I actually have the stripe on the spoiler, not just the car.
Car: 87 GTA
When I looked at his pic, I saw more of a shadow showing the side contour of the stripe, not the stripe ON the spoiler.
Car: 1989 Camaro RS
Engine: mild built vortec 350
Axle/Gears: Stock
did you ever decide on the final idea and get it painted? I thought this was a cool idea and would like to see it finished and get a full side profile.
Car: 1992 25th anniv. camaro rs
Engine: 3.1L V6
Axle/Gears: stock
Why dont you see what it would look like with the stripe on the front of the car like the late 60's camaro
i did originally try to lay out a stripe in the front and i couldn't get it looking right. in my opinion the car has too much going on with the angles of the front bumper cover to get it looking right. BUt if someone else wants to lay one out on their car i would like to see if you can come up with a way to do it!
also.. i am in the process of jambing the car and it will probably be spring (or summer at the latest) until the car is painted. money is definitely a big issue.
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I'm sure it will look good, but I keep thinking of Mopar when I see a stripe around the back.
Car: 1997 z28
Engine: lt1
Transmission: t56
Car: '84 Z28, '06 Scion tC
Transmission: auto
that has got to be the biggest compliment ever! i know that some people are not going to like it... but i do. i plan on having a decal made so that i can remove it some day if i ever want to put original style decals back on the car.
thanks to everyone on here for the input.. good and bad. all of the opinions can only make the idea cooler in the end.
Car: 1989 GTA
Engine: 5.7 350
I think the idea is DOPE. I think everyone should add a little bit of individuality to their car, plus it just makes the car look generally more badass
well, I liked the inverted text in the original, so if you like the current tapered and outlined version, something like this:
or IROC-Z is probably more appropriate:
would it be possible to put iroc-z in this design.. or would it look too small? i think i like this one best for me.. but it would be awesome to have the z in there too. i also wouldn't mind seeing it with the skinny stripe coming around the bottom of it. maybe widen the stripe on the back part, leaving the same gap between the stripe and spoiler as there is between the stripe and pin stripe. then bring pin stripe to meet the spoiler on the bottom. widening the big stripe even that much may help to fit the z in there..
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i think it would look better with the strip continued all the way down, stopping halfway looks kinda out of place IMHO.
Did something similar on my bird, did the mopar stripe with the bird on it. I like it, usually get compliments on it.
old pic, sorry
old pic, sorry
Car: 1986 Sport Coupe
Engine: 305 Carbed
Transmission: th700r-4
I think this idea looks very good, I'd steal it when I paint my car, but then I'd feel like a jack-***, lol. //<86TA>\\, that bird is effin beautiful.
as far as i'm concerned anyone who wants to use the idea is more than welcome. as a matter of fact i think it would be cool to see the different variations and see it on some other cars. if you like it and want try it i say go for it! just post up pics when you're done!
that does look sweet!
i never said i didn't like it! i was only throwing out an idea.. i do think the wording looks better now though. THANK YOU!
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I was wondering what it would look like with another thin stripe on the other (back) side. Do you also have the correct font font it as well?
