general question regarding wheel wheights
Old Oct 16, 2009 | 07:50 AM
quique's Avatar
Hi there,
I'm new to the forum (and to the Camaro).
Just bought recently a 91 RS with 245/50R16 wheels on it.
Today I had the 4 tires replaced as they were in very bad condition.
I paid also for balancing, and later on in the day, I noticed they had fitted those ugly 'conventional weights' (please see attached picture).
I was shocked they did that on a sports car wheel. I understand that would be done on a regular passenger car with regular tires, but on a sports car with wider wheels, I would've expected they would have used those 'adhesive back stick-on wheel weights' or similar that get stuck on the inner side of the wheel... right now, the wheels look terrible (see pic)
You might find my question irrelevant or dummy, but I'm from Europe and not used to the things being done here on cars, so I wanted to ask about your opinion... so I can go tomorrow to that place and tell them to remove/replace them and/or give me my money back... that is unacceptable to me cosmetically, I don't care if the car is 20 year old (btw I went to W*M, b/c is just by my place so it was convenient, although it might have not been the best thing to do...).
Thanks for your help...
________________________________________________________
Just as an anecdote, I find similarly that here when they change your oil, they do it the old fashion way, by lifting the car and removing the bolt on the bottom, while in almost everyplace 'on the other side' they suck it from the top (even Mercedes figured out it is more efficient that way and do that here on the dealers).
Old Oct 16, 2009 | 08:56 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: general question regarding wheel wheights
I don't know about were you live but around here you have to request the stick on kind. Last time I had my tires done they did the same thing and ruined the clear coat on my rims. I don't care as much now bc I bought new rims for my car and have a buddy who will do the mount and balance for me.
Old Oct 16, 2009 | 10:18 AM
1Aauto's Avatar
Former Sponsor
The problem is that they don't care. When I have my tires balanced I tell them to put the weights on the inside lip,and not the outside.
Old Oct 16, 2009 | 06:20 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
i dont trust sticky weights ask them to put it on the inside lip next time
Old Oct 16, 2009 | 08:45 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Most places I have worked only use stick-on weights when requested. If the correct hammer-ons are used they shouldn't damage the wheels and only using weights on the inside lip is not as accurate as both sides, and may result in a high speed tire shake. If wheels are cleaned with the right cleaner stick-ons will not fall off. I'm currently working at a VW dealer and all there aluminum wheels have no lips for hammer-ons and must use sticky's...I've never had any fall off.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
