tell me what u think
Old Sep 16, 2010 | 02:25 PM
jdrs89's Avatar
This my 1989rs 355 bluprint engine just want to kno what you all think, its a work in progress
Attached Thumbnails tell me what u think-l_a4dfdd0a99264dca9c5d897eee4e5e49.jpg   tell me what u think-l_ef373ab5dfe14c318dc156cb91b21615.jpg
Old Sep 16, 2010 | 04:07 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: tell me what u think
look good considering what it could look like
i would clean up the spark plug wires with some of those clips instead of running them over the wiper motor
Old Sep 16, 2010 | 04:50 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
You could also remove that AC/Heater core assembly, its not hooked up anyways, and it will go a long way's to give that clean engine bay look, not to mention added room for whatever. It'll only take minutes and wont cost a thing. U can use almost anything as a block off plate, aluminium, steel, even fiberglass or better yet a piece of carbon fiber found on ebay for cheap, or where ever.
Old Sep 20, 2010 | 01:15 PM
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
i hope you aren't driving that with the brake booster unhooked. you might be getting a bad vacuum leak as well
Old Sep 28, 2010 | 12:29 AM
jdrs89's Avatar
nah these r jst shots of it befor it even hit the road made alot of changes since then will get more pics up soon will b completed once i figure out why the trans is squealing
