Are leds waterproof?
Car: 1991 RS
Engine: 350tbi
This might be a dumb question but I got some undercar leds and I was wondering if I should be worried about driving in rain.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Are leds waterproof?
an led is, but the circuitry its attached to isnt waterproof naturally, but kits for under lighting on cars and such are usually sealed and fully waterproof. It should be pretty easy to tell, if you see bare circuit board, its not waterproof, if its all in a tube of some kind, it is waterproof.
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
well wire is water proof but how did you do the connections? if the connections are tucked up and shrink wrapped then yes your good but if they are hanging down with a bad electrical tape job then it will short out. Lastly, you should have a fuse inline with the power source so just in case water gets in somewhere it will blow the fuse and nothing else
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
