Questions - Those with Aftermarket Clear Parking Lamps
Old Mar 4, 2011 | 03:44 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Hello,
This is for those with the aftermarket clear parking lamps.
I was wondering where you got your parking light assembly kit from? How much it was? Is it a direct replacement? Is it sealed or does it have "breathing" holes (which tends to allow water and moisture in for the factory ones).
Apparently they are all (that I can see) "DEPO" brand.
Thanks very much
Old Mar 4, 2011 | 08:15 AM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: Questions - Those with Aftermarket Clear Parking Lamps
http://www.360tuners.com/camaro.aspx
i have the smoked front /sides. ive never had a moisture problem inside. im planning on getting the clear lenses and going with switchback leds for the front turn signals.
http://autolumination.com/switchback.html
Old Mar 4, 2011 | 02:04 PM
I do have to say that website 360tuners.com is COMPLETELY MISLEADING. Claiming those cheap "DEPO" (not depot) brand are worth $199.99 and you're saving $150.01 is just WRONG.. Depo are only worth around $49.99 EVERWHERE else.. Looks like they just make up a price to make you buy. That's like chevy saying the new ZL1 is going to worth $150,000 but they will sell it for $59,000 (if that is what it will sell for and every other dealer is selling it for around).
That is just wrong.
But anyways.. Basically it's plastic with a "chrome" plastic different internal than the stock? Is that correct?
Old Mar 4, 2011 | 02:15 PM
and the clear plastic side marker lights are worth $89.. Interesting.. Considering the entire kit is only worth around $69.
Old Mar 4, 2011 | 06:27 PM
zee28's Avatar
Car: 86 iroc
loanroad,how long have you had them installed and are they holding up good?
Old Mar 4, 2011 | 07:50 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I like that LED tower bulb!
loneroad; are you going to go with the 20 or 30 LED bulb?
I am so doing this now!
Old Mar 4, 2011 | 07:58 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
These were well worth every penny in my opinion and really finished off the front of the car. I almost bought the crystal ones off eBay but finally decided against it.These are exact replicas of the original including what is called "opaque" lenses.They have the breather holes like the stock but have had no problems . Here's were I bought them and a photo of them just out of the box . ($85.00 is a little pricey, but as I said well worth it).Here's a link to "1a Auto"Where I bought them. who is also one of our sponsors here on ThirdGen.Org = http://www.1aauto.com/1A/HeadLights/...08/271776/1989
Old Mar 4, 2011 | 11:20 PM
I think I like the ones that the O.P. put up. I just like the lens better. Just my opinion though. Really, I think they both look good.
Old Mar 5, 2011 | 12:01 AM
O.P?
Old Mar 5, 2011 | 12:50 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
the OP is you(original poster) i personally like the clean stock replacments from 1a auto, the others look to fake. ive had some decent luck with sanding down stock lenses and polishing them back out.
Old Mar 5, 2011 | 10:57 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
about 3 yrs. the car did sit uncovered for about a yr and a half tho. at the time i was going with a blacked out theme. lenses/ marker, and tinted headlights. but now with new wheels and a billet grill, imm going back to the clear look.
Old Mar 5, 2011 | 11:02 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
i have to measure the hole first, but prob the 20
one of the guys that i work with has a 300m show car.he has the 30s and they are bright.
Old Mar 5, 2011 | 01:47 PM
The LED towers look like they would light up the housing better. I was on the fence about using LED's til I saw those. I found something else to use my tax return check on, now! Thanks for posting that Guys!
How soon are you going to do this loneroad?
Old Mar 5, 2011 | 09:51 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Here are clear lenses on my camaro.
These are the tower LED's I'm using
Old Mar 5, 2011 | 10:06 PM
And those fit? In the pics they look yellow (In the housing) Looks nice!
Old Mar 6, 2011 | 04:29 AM
any pics, video with them installed?
Old Mar 6, 2011 | 11:32 AM
Car: 89 IROC
I haven't installed the LEDs yet. I did test fit them when I first got the lights and housing. It is a very tight fit (the light just touches the edge of the opening) and needs a light tough to install.
Old Mar 6, 2011 | 01:11 PM
88camaroluvr's Avatar
I got those and when the front end is in direct sunlight you cannot tell the turn signal is on. And it didn't change even when I put the high count led bulbs in. I actually had to add two strips of amber leds into each one and now it's noticeable all the time.
Questions - Those with Aftermarket Clear Parking Lamps-2011-03-06-13.04.05.jpg
Old Mar 6, 2011 | 02:20 PM
hairysox33's Avatar
I got mine off of ebay. Type in 1982-1992 camaro and they should be in the first couple pages when they are listed. Got mine for $20?
Old Mar 6, 2011 | 02:22 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
I've got the smoked ones and have had on car for over a year with no issues with moisture.... even with all the rain we get
Old Mar 6, 2011 | 09:08 PM
Someone definately has to post a vid of them flashing. I was a little worried they would "Wash-out" in bright sunlight (Which is almost every day where I live)
Old Apr 6, 2011 | 11:15 AM
redzee28's Avatar
Car: 1985 z28
I've had the clear parking lamps for almost 3 months and i havent had a problem at all. But i did install LED's but my problem was that they wouldn't blink it would just stay solid. Anyone know of what was the problem?
Old Apr 6, 2011 | 03:55 PM
When you install led's you need an electronic flasher. Without it (Using your stock flasher.) they will either flash very fast or not flash at all. They are pretty cheap and available at your local auto parts store.
Old Apr 6, 2011 | 04:22 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
as far as the moisture problem... there was a recall many years ago, and they would cut a notch in the bumper underneath the breather hole in the parking lights.... on later cars (91/92) i believe it was addressed from the factory, water would puddle up underneath the breather hole and get up into the light
i have the crystal clear parking lights now with LED's
best pic i have of them lit up... they're not that blue in person tho
Old Apr 6, 2011 | 07:04 PM
redzee28's Avatar
Car: 1985 z28
never heard of an electronic flasher. how do you hook it up?
Old Apr 8, 2011 | 08:17 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
For you guys who wanna be cheap, you can always polish up your factory lights:
The discoloration at the top is actually mold INSIDE my parking lights. It's upside down here, apparently water pooled inside it somehow - and it's a 92 car too, so whatever the factory fix was, it wasnt that effective.
How they originally looked:
I should probably get some of those DEPO lights though, they'd match my headlights a lot better. That said, I was expecting them to fade out and re-oxidize, but that was over a year ago and they look just as good now as they did then.
Old Jan 11, 2012 | 11:07 PM
Any pics/video of the LED lit up?
Old Jan 14, 2012 | 10:16 PM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
I too replaced mine with the depo's definatly a night and day difference, makes the whole front end look nicer. though my old ones had vht spray on them...
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
