how do you remove seats from 92 Convertable
Old Jul 20, 2011 | 01:47 PM
polara1965's Avatar
Hi, can anyone tell me how to remove the seats from my 92 rs convertable, back seats especially i have seats from a 91 and they are power is there a plug under the seats i have now to plug them into? thanks for all your help folks!
Old Jul 20, 2011 | 01:59 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: how do you remove seats from 92 Convertable
through the top.
Now in all seriousness, the powered seats have a plug underneath the seats. Should be no different for convertibles.
The seats sit on rails. The rails have plastic caps on them. Take off the plastic caps, remove the 4 bolts for the seats, pull them aside (doing the back seats first, then pulling the fronts back should give you space) and unplug the plug.
The back of the rear seats have a bolt in the lower corners left and right, the seats theselves are secured with a single bolt up front. If you have a split rear seat, they still only have 2 bolts. The centre part is just a pin.
Old Jul 20, 2011 | 02:02 PM
polara1965's Avatar
the seats in the convertable dont have a plug, how are back seats attached? so there shuodl still be a plug even if there was no power seats to begin with?
Old Jul 20, 2011 | 02:04 PM
Engine: LO3
Just edited my previous post regarding the backseats.
The non-powered fronts have no plugs. I believe the wire harness for powerseats is still there, but only for the drivers side.
Old Jul 21, 2011 | 04:56 PM
salcontreras10's Avatar
Car: 91 Z28 Convertible, 2000 trans am
Engine: ls6, ls1
Transmission: 4l60e
There are only two bolts for each rear seat. One just below each seat cushion on the front and one on the outer parts of the back rest. You need to remove the cushions before you can get to the back rests.. if you need pics just let me know.. ill snap a few for you.
Old Jul 21, 2011 | 05:02 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Unbolt them. 4 bolts on each front, 2 bolts on the rear....
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
