how to clean aluminum intakebmanifold
Old Oct 25, 2011 | 08:05 PM
1987_sportcoupe's Avatar
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
So with the engine I bought came a holley contender intake that I found out is a pretty good intake so I want to keep it. Its in good shape but I want to clean all of the carbon buildup out of the inside of it. The machine shop down the road said they wouldn't hot tank it because its aluminum. I heard that glass blasting is a pain and jet spray doesn't get all the carbon off. How should I go about cleaning this?
Old Oct 25, 2011 | 08:48 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
Re: how to clean aluminum intakebmanifold
B12 spray can and rags
Old Oct 25, 2011 | 09:44 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Do you have a power washer ? If you do try this,go to the parts store and buy some etching aluminum wheel cleaner,it is a mild acid. Get enough to submerge the part,let it soak for a few minutes then power wash it,repeat if needed. I have a place by me called DW DAVIES they sell a wide array of chemicals,they even have DW 40 not WD 40 but any way I bought their wheel cleaner and it is called wheel bright it was about $10 a gal. I submerged my brake calipers and an enderlie fuel injection manifold for a 426 hemi in this acid. After a few minutes you could see black stuff only in the low spots of the textured surfaces and I couldn't get it off. My buddy said POWER WASH IT ! So I tried that and WOW like brand spankin new. Again this stuff is acid you must wash very well to remove all the acid or it will keep eating the aluminum. My brake calipers were dirty,painted,caked with brake dust,just plain nasty,your typical used calipers. now they are like new.
Old Oct 25, 2011 | 09:58 PM
91ls1t56's Avatar
Car: 91 Z28
Some results.
Attached Thumbnails how to clean aluminum intakebmanifold-dsc00945sa.jpg   how to clean aluminum intakebmanifold-dsc00936hm.jpg   how to clean aluminum intakebmanifold-dsc00926e.jpg
Old Oct 25, 2011 | 10:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Carb and choke cleaner will get the big stuff cleaned out fast. then you can pressure wash it. whan all the oil is off you can use muratic acid from any big warehouse type lumberyard. be VERY careful with that stuff. thick rubber gloves and eye protection is a must. put some in a squirt bottle and spray your intake a lil let sit and rinse.
itll look nice an brite if done properly..
Old Oct 26, 2011 | 06:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
you might try aircraft cleaner.
Hotrodboba400
Dec 10, 2019 07:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
