window oxidation
Old Dec 20, 2011 | 04:09 AM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
window oxidation
hey all, i have a 92 with i call it oxidation on the rear window. it is like a cloudy effect and i cant find new glass up here, damn AK. lol. any ideas on a product to use to remove this. thanks
Old Dec 20, 2011 | 04:54 AM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: window oxidation
Any pics of this? I'm not sure what you are talking about...it doesn't wipe off? I assume you tried that.
Old Dec 20, 2011 | 08:12 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Sounds like buildup of rain deposits ect. If your windows are not taken care of regularly this is what happens.
This is what you NEED
Tools and Products
  • High Speed Rotary Buffer
  • M04 Heavy-Cut Cleaner (Meguiars)
  • Glass Cleaner
  • 3" Wool Cutting Pad
  • Blue Painter's tape
  • Microfiber
You can not just simply use any BS over the counter orbital buffer with any pad. It NEEDS to be a High Speed Rotary w/ wool cutting pad or at least a foam cutting pad. If you dont have access or dont have the funds be prepared to be disappointed, but you can bunch up a cotton terry towel in your fingers and go to town with the M04. It will take a LONG time and if you are not experienced you most likely will give up because of not seeing results right away. That's why you really need a Rotary.
That being said here are some before and afters of a job that was done with the same equipment I just posted.
Old Dec 20, 2011 | 12:33 PM
clean92rs's Avatar
Car: 92 camaro RS
no i dont have any pics as it is covered for the winter with a cpl inches of snow , and thanks for the help all. ill give that a try black. can u give me a brief break down of what steps to do. i have a idea but confused where the wool pad come in to play. thanks.
Old Dec 20, 2011 | 01:59 PM
Car: 1985 IROC-Z
Engine: 355
Like I said we are not talking about a crappy rotary buffer like this.
We are talking about one like this.
With a 3" wool cutting pad on the backing plate like this one from buff and shine.
Step 1: Clean and wash windows, make sure they are completely dry.
Step 2: Mask edges around windows. So you dont marr your paint.
Step 3: Prime the pad with quick detail solution.
Step 4: Add some m04 to the pad, work it on the surface and then hit it with high speed.
Step 5: Work the machine back and forth, up and down until you can barely see the compound anymore.
Step 6: Wipe with micro fiber, and repeat until desired result appears.
Old Jan 8, 2012 | 05:53 PM
Chachi361's Avatar
Car: 1992 Camaro rs
Engine: Stock 305
Transmission: 5 speed
Rubbing alcohol with salt will clean that with ease.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
