Need help ordering HIDs from DDM Tuning?
Car: 1986 Iroc-Z
Engine: 355
Hey guys,
Well i know that ddm tuning sells an HID kit for 30$ but when i go on to the website i cant seem to find a kit specifically for 82-92 camaros.
I tried searching by car, but when i click on Chevrolet it throws me to a page with a bunch of cleaning products.
By the looks of it, i have to manually choose the options for the HID kits.
Can someone shed some light on what options im supposed to pick for the kit to work with our cars?
Id like to get the brightest light possible in white, without any blue tint.
I see
Raptor full size HID Kit;
Wattage:
bulb type:
bulb color:
Hid Harness:
Error code eliminator:
adaptor cable:
Mounting brackets:
Besides the ovbious like mounting brackets and bulb color, i have no idea what the other options mean, anyone help me out on this?
would be greatly appreciated
Thank you.
I see
Wattage:
bulb type:
bulb color:
Hid Harness:
adaptor cable:
Mounting brackets:
Thank you.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need help ordering HIDs from DDM Tuning?
you will need to replace the housings from the sealed beam and order a hid kit as well.
for example you low beams are H4656 so you need a housing for that and than a hid kit.
6000k is the white color and they will be brighter than your high beams.
http://www.ddmtuning.com/Products/4656-Halogen-Lamp
http://www.ebay.com/itm/H4656-4-x6-C...ht_1673wt_1055
Car: 1986 Iroc-Z
Engine: 355
Yeah i got the housing part covered i plan on getting those from ebay, im just having trouble ordering the hid kit itself from this particular site.
Engine: Lb9
Transmission: M20
Car: 1986 Iroc-Z
Engine: 355
Thanks! question though, what about the harness option? Would it come ready to plug and play with the stock connectors without one?
Engine: Lb9
Transmission: M20
I doubt it, you will need to install some male spade connectors to go from you low beam harness and the ballast wrap this up real good with electrical tape or shrink tubing. I converted over my wifes saturn vue to hids if had drl so I had to disconnect the resister for that and wire in a relay to get the ballast to come on.
Car: 1986 Iroc-Z
Engine: 355
Damn i was afraid of that. The last kit i bought locally came plug and play so it was extremely easy to mount the hids. I ended up paying like 55$ though.
I was hoping the ddm tuning kit would come plug and play also.
Engine: Lb9
Transmission: M20
if you did get a relay wiring harness kit off ebay it is a easier install you just wire the relays power and ground and the trigger off of one of the head light pigtails and your done.
