Getting ready to paint the calipers tomorrow or the next day. Last min questions
Old Nov 19, 2001 | 04:31 PM
Monkie's Avatar
Ok so I plan on taking them off the rotor. Should I take the brake line off of them too or just let them hang there? Anyways I got High Engine Heat red paint and I also got High Engine Heat clear paint. Thinking it would act as a clear coat. I asked the guy at AutoZone if he thought it would work as a clear coat and he said he really didn't know. But he said that he didn't have any high heat clear coat paint so I was SOL. What should I do about the clear coat? Will what I got work?
Old Nov 19, 2001 | 04:38 PM
camaro6spd's Avatar
don't let them hang buy teh brakelines.....tie them up there with some wire...i don't trust the brakeline....even if they undergo extreame pressure....better to be safe then sorry.
Old Nov 19, 2001 | 06:14 PM
Monkie's Avatar
Ok better yet here, how do I take the caliper all the way off the car? What do you do just pull the brake line off the caliper? BTW, that will cause all the brake fluid to drain out right? How do you fill it back up? I guess this would be "bleeding the brakes"
Old Nov 19, 2001 | 07:01 PM
simon's Avatar
There are 2 bolts that hold the caliper to the backing plate (PBR setup). As far as the fluid leaking out, just use some vice grips and clamp down on the hose. Place a towel on the line before using the grips so you don't accidently gouge the line. Then unscrew the bolt that holds the brake line on and the caliper will come right off. Also, you might want to pick up some aluminum washers for the brake lines (4 total) to replace the existing ones. Again, this was for my 89+ setup. I don't know if its the same for -89 setups.
89 RS V8,Borg-Warner 9-Bolt rear,Open element,Flowmaster.
Old Nov 19, 2001 | 07:11 PM
un4givin89's Avatar
If you dont' know how to take the calipers off don't be doing this. Second, spray paint won't cover these very well. Clean them with lots of Castrol Super cleaner. This is how I did mine. I suggest you get a thick brush and brush the paint on. Works alot better.
Old Nov 19, 2001 | 07:52 PM
Monkie's Avatar
Thanks Simon that is a good idea. I think that will work nicely. Im gonna prime them too to make it look nicer. My question is would the high temp clear PAINT work as a clear coat?
Old Nov 19, 2001 | 08:41 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
It probably will. But when you prime,use the high temp prime also.I used the hi temp prime and hi temp red paint on mine about a year ago and they are still bright red(when they're free of brake dust).
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
