True LED american made 4x6 headlights
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Yes they are expensive, but an alternative to doing the HID projector swap maybe?
http://www.tlg-auto.com/JW_Speaker_8.../led-8800l.htm
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Re: True LED american made 4x6 headlights
I think I like HIDs better, maybe not as crisp but alot less cheaper.. But who am I, I still have lights from 1985 lol
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Shame they don't have a hi/low beam setup for the firebird guys.
Car: 1985 IROC-Z
COTM Editor
The prices on those have come down a bunch! When they were introduced a few years back the pair was almost $1800! I first saw these being used in the trucking industry. I can see why truckers have been willing to spend the extra money on these I am very impressed with the light output on those.
COTM Editor
These...
http://www.jwspeaker.com/products/he...product=500227
Use them on the outside, and put 4x6 air ducts for brakes or turbo, or something sweet on the inner lights
Car: 1986 IROC-Z
Axle/Gears: 4:10
Pretty cool. I like the look on those, but the pricetag is scary. I used to have a 4th gen and in pursuit of better lighting i removed the sealed bulbs, fabbed up a bracket, and mounted some similarly sized PIAA bulbs. It cost me about the same as ONE of the above lights and it caught a lot of attention.
Car: 1985 IROC-Z
COTM Editor
Keep me in the loop. Maybe we could get a group buy organized?
Car: '91 TA vert
Engine: turboLSx
LED headlights are amazing. I love them. That's actually about half as much for the 5.25" round LED headights I found for my e30. However, the lumen output seems low? Are LEDs looked upon/measured differently than typical capsule headlights? (HID/Halogen/Incandescent) A regular D2S puts out between 2400-3000 lumens and that says effective lumen output 750-850?
Transmission: Pro-built 700R4
Will they mount properly in the Firebird bezel?
COTM Editor
Be the first man! I will envy you.
I'm interested in the 8800H/L headlamps but they don't have a price... at least not from what I can tell. Their website is kinda crappy.
Where?
I agreed completely. Interesting product, but not a very well organized website to gather information. Seems more flashy that substance.
This is from the TLG website regarding the 8800:
"The low beam LED lights replaces H4656 headlights
The high beam LED light replaces H4651 headlights"
Still curious about the 8800H/L and if they'll fit the firebird bezel.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
http://www.jwspeaker.com/products/he...-low-headlight
Edit: On second thought, they won't fit Firebirds. They're sized for a hi/lo-hi headlight system, not the hi/lo headlight system that Firebirds have.
Those ones mentioned above are their hi-beam, and lo-beam setups which is what the Camaros have. They do have a Hi/Lo-beam in their catalog, but I cannot seem to find it anywhere else. I suspect that it might be a canidate for the firebird setup (i.e. the 4666). I sent them an e-mail asking for more info.
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Subscribed. If they have something for the Firebird bezel with hi/lo beam that is a direct bolt in, I will buy a set definitely.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
1300 raw, 850/750 (hi/lo)Effective (actual) lumens @ 45w Vs 3200 Lumen for a typical HID 35w, meh.850 is around your typical halogen lumen rating.
I got a reply back from the people at TLG Auto. This is what they had to say about the 8800H/L lights and their applicability to Firebirds:
"Great question! JW Speaker has three 4×6″ LED headlights: The #8800L (Low Beam Only), #8800H (High Beam Only) and the 8800 H/L (High and Low Beam). About the 8800 H/L, you can see the specification sheet here: http://www.jwspeaker.com/products/he...-low-headlight
The problem with 8800 H/L is that it is roughly the 4×6″ shape, but it’s not made to be a drop-in replacement for sealed beam headlights in passenger cars. Firstly, it is about 4.5″ x 6.6″, which may not fit some 4×6 openings. Secondly, it is 4″ deep with no tapering on the back side – it’s totally square in the back – which means you’d have to modify the headlight fixture of almost any car to make this fit. Lastly, the 8800 H/L has 3 cast mounting tabs on the outside frame of the light because it’s designed to be flush-mounted on a flat surface in industrial or universal applications.
What it comes down to is that “Yes” JW Speaker does have a 4×6 high/low LED headlight, but it’s not designed to be used as a replacement headlight for passenger vehicles. You could theoretically use the JW 8800 H/L in a car with 4×6 headlights, but you would need to modify both the headlight AND the housing on the car that holds it in place.
If you want a drop-in LED 4x6 headlight that does both high beam and low beam I suggest this headlight:http://www.tlg-auto.com/GTR_4x6_LED_...0003.htmThanks for your additional questions! Please let me know if you have more.
-Chris NelsonOnline Sales Manager
www.TLG-Auto.com"
The GTR lights he references at end of his message are about a $100 cheaper for a pair than the other LED lights are for just one.
-Eldon
www.TLG-Auto.com"
-Eldon
Car: 1985 IROC-Z
www.TLG-Auto.com"
-Eldon
www.TLG-Auto.com"
-Eldon
That GTR headlight is disappointing to say the least.
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Glad I came across this post. I saw these in a booklet somewhere and was going to research into getting them. Guess it is a no-go.
Another year and someone will have one for cars.
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Technology is only gonna get better and cheaper. been waiting years for these lights, guess maybe another year. the LED lights for inside the house are finally getting to a good price/output, hopefully cars soon.
Guys, I am all for upgrades and personalizing your ride but $1600 for LIGHTS?!?!?!
I'll stick with my $20 Silvanias from Pepboys... I can buy a shortblock for $1600...!! Or a COMPLETE leather interior, carpet and Dynamat, or a set of wheels AND tires, or a good paintjob, or a killer sound system, or...
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
With as clean as your car is, I demand you get updated lighting. However I would like to see a setup on yours similar to what is done on some import 240s like a lazy eye, so the whole headlamp doesn't flip up and ruin lines. Or maybe a exposed headlight like a new vette or like the c5s are doing to theirs?
Car: '91 TA vert
Engine: turboLSx
Don't worry, mine are upgraded. I did a bixenon HID swap a bit ago using retrofitsource's tiny morimoto projectors. And actually, I chopped a bit of the bracket up to prevent it from opening all the way (and correct the angle of the lens assembly). When a bird's lights are up, especially a 91-92 car, there is SO much unused space. I don't have any sort of bezel around the whole thing like factory but eventually I'll get time to finish that. Probably after I get the car tuned and back on the road. Senior Member
Car: 1992 RS
Transmission: Automatic
So if one was to get these LED headlights the normal high beam lights on our cars would just sit there useless? Kinda gay. I would like it better if they had a version that incorporated the dual-style headlights
Car: '91 TA vert
Engine: turboLSx
Well there's nothing stopping you from leaving the high beams hooked up, they'd just be horrendously different colors and brightness...
Car: 02wrx/88 rs
Not really, there is a model for high and a model for high. If you got all 4 you would not really notice. I don't see the need for a dual beam on the camaros. It would be difficult for one because of, what would be filament placement, and two correct aiming. If you watch the video, the low beams shine very far and pair that with high beams there would be not a big advantage at that point to have dual in middle unless you want to spotlight someone off the road.
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
You can not advertise your product if you are not a site sponsor
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Subscribed in the hope they'll come out with an HID option for Firebirds!
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
This guy makes some pretty cool lights.
https://www.facebook.com/SkinnyBoyLighting
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Took years to slim down HID systems for automotive applications.Probably be a while for LED tech to catch up to HID lighting.It barely matches halogen currently.
Engine: 5.0 L03 V8
Not sure I've seen people on here assemble their own lights similar to that guys though.
Car: 1992 RS
Or just become a vendor...> Either way if you got a good product and the price is right hopefully the sales will follow
Car: had 88 Formula, 91 RS and 94 RS
Thank you for the advice I will most likely try one or both of those options.
Car: 1985 IROC-Z
Bumping this back up. Truck lite has come up with the best (in my opinion) true LED 4x6 replacement. They are due out at the end of this month too! I tried to confirm pricing on these from Truck lite, but they wouldn't give it to me because I am not a dealer. I did find a couple sites that are listing them for between 165-200. There is a low beam light and separate high beam light. Pretty excited to see these.
Looks very interesting. Wish they'd have a H/L kit to replace the 4666 bulbs.
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
List is $258 per light. I don't want to post dealer pricing since some of the site sponsors might start carrying these. But I would think you should be able to pick them up for about half that or maybe a bit less. Still pricey, but not as bad as before. They have an interesting look, I'm curious to see them on a thirdgen. I'm running the trucklight 4x6 glass housing with a 9007 bulb right now, they make good stuff.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Car: 1985 IROC-Z
