Tire Advise Please
Tire Advise Please
I have an 87 Formula with 16x8 inch rims. The car calls for 245/50/16's with a V speed rating. I have a few questions:
Is anyone running a larger size than this on there 16x8 inch rim? What is the max ic can put on it 255/265/275? Also, I'm kinda on a budget. In other words, I'd be willing to spend the money but want to see if anyone knows of some good deals on preferably Z rated tires.
Do you know of any manufacturer that sells Z rated 255 or 265/45/16's?
Any help would be greatly apreciated.
BFG,BRIDGESTONE,ECT... all make the tire u r looking 4 but the 265 is a rare width to get besides on your rim 255 is plenty big!
look @ mine 255/50/16 on rear,245/45/16 on front
http://wsphotofews.excite.com/004/us/dv/WM/ab70948.jpg
http://wsphotofews.excite.com/013/Mh/N4/VL/9i60002.jpg
http://wsphotofews.excite.com/024/ke/Js/jl/9M35152.jpg
go to the www.tirerack.com and enjoy
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4 TCI STREET FIGHTERTRANS,TRANSGO-HP KIT,KEVELAR CLUTCHES,VETT SERVO 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,L-98 ALUM. HEADS PORTED CRANE AFPR.45PSI,SMOG PUMP GUTTED,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 DUMP
MSDDIST,6AL,TAYLOR WIRES
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.23 AND MOSER AXEL SPLINES CRYGO FROZEN,TUBE FRAME CONNEC,EIBACH PRO.,HOK.LOWER ARMS,PAN,TQ ARM,ALUM. DRV.SHAFT.
PST KIT.1LE BRAKE KIT CROSSED DRILLED ROTORS MANY MORE MODS FORESEEN IN MY ERA!13.01ET @ 108.75MPH ON MICK E.T & PIZZA CUTTERS UP FRONT
[This message has been edited by ONEFORMULAOVERALL (edited December 09, 2001).]
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
