Engine bay AC parts firewall removal for paint
Old May 20, 2013 | 12:42 PM
M3638's Avatar
Car: 1990 Iroc Convertible
Hello all, I'm new to the site. I recently picked up a 1990 Iroc Convertible, 305, automatic as a project car. I currently got it running (it needed new injectors) and engine feels strong. It needs work.
Next week I plan on removing the engine and everything in the engine bay in order to take it to the body shop to have it painted , original blue. I'm ok with tools and have removed a tpi motor in the past from an 89 Iroc that I owned years ago. What I'm not so familiar with is on the removal of other items on the firewall. I think that the problem I will have the most problems with is the "AC stuff".
I'm looking for any suggestions/ insight to get this done without to many hangups. Also, I don't remember if I had to take off my tpi system in order to pull the engine out. Can I just remove the distributor and some pieces up front which will enable me to put a chain front/ rear and pull it?
In advance, thanks for any help/ suggestions.
Old May 20, 2013 | 12:51 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Engine bay AC parts firewall removal for paint
I pulled mine with TPI and distributor all attached. I just removed the hood, serpentine brackets, pullies, and power steering pump. I used a chain from front accessory head bolt to the rear head on the opposite side. I used a long reach hoist I bought from Harbor Freight. I pulled it over the front of the bumper just fine.
For AC stuff you're suppose to get it discharged properly before removing. Some shops around here will vac the system then you just have to pay for the refill. Shadetree method is just purge it to the atmosphere which is not legal.
Biggest thing label everything! I mean everything and keep it all neatly organized. I spent 2-4 hours one time looking for the wiper motor bolt in a pile of bolts in the garage.... NOT FUN.
Old May 20, 2013 | 02:23 PM
M3638's Avatar
Helpful, thanks. What about suggestions on the firewall AC stuff? EZ to take apart?
Old May 20, 2013 | 03:49 PM
Engine: 383 SBC
Mostly o rings. So easy to take apart. Heater box might be brittle due to heat from headers. I removed it all since I drive less than 7k miles a year. I just tossed all the stuff, you'll have to be more careful. Condenser in front of radiator was toughest connection for me. I ended up bending one of the tubes. Because connection nuts were stuck.
Old May 20, 2013 | 04:23 PM
M3638's Avatar
Got it. Thanks again.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
