Best Way to Clean Rims?
Old Aug 4, 2013 | 05:56 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Picked these rims up and would like to give them a quick clean. Looks like water spots on the clearcoat.
What is the best way to proceed to clean up the rims a bit without stripping off everything and polishing.
May sound like a simple question, but I don't want to damage the rim or the clearcoat.
Suggestions?
Old Aug 5, 2013 | 08:54 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: Best Way to Clean Rims?
I'd try a clearcoat polish first. If that doesn't work, rubbing compound.
Old Aug 7, 2013 | 02:47 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
looks like the clearcoat is pretty far gone. i had a set of wheels with the same spotting, a little less really. i had figured the clear was shot. when i took the clear off the spots were still slightly visible. without sanding anything, i used tripoli on a stiff buffing wheel and the spots came out. even brought out a little color in the aluminum. the rubbing compound is worth a shot, but if that doesnt work, the spots may be beneath the clear.
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
