looking for instructions to install 4th gen center console
Old Dec 28, 2001 | 08:55 PM
86Street's Avatar
subject:
Old Dec 28, 2001 | 09:26 PM
un4givin89's Avatar
Heres what you do, unbolt the other one and bolt the new one in. THERE ARE NO INSTRUCTIONS CAUSE ITS SELF EXPLAINTORY. About 4 bolts hold the old one in and about the same for the new. All ya do is sit it in place, line up the holes and put the bolts in then screw them.
Old Dec 29, 2001 | 02:21 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Well, you have a Camaro, so I am not all that sure about how it is on those, on mine it was remove old console, install new console and use the 2 bolts that are in the armrest compartment.
The other screw up front doesn't have a place to be mounted on the new console. It fits really tight and doesn't move at all.
Here is mine,
Old Dec 29, 2001 | 10:39 AM
86Street's Avatar
well its for my friends 85 t/a.so if you can just post instructions.thanks
Old Dec 29, 2001 | 03:27 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
The 3rdgen Camaro radio pod and climate controls are attached to the center concole. Is it that way in the 3rdgen Firebird? If not, I guess you could use a 3rdgen Firebird dash/insturment cluster and a 4thgen center console. Maybe?
EDIT: Oops! My bad! I thought it was for your Camaro...
Old Dec 30, 2001 | 03:47 AM
Zepher's Avatar
First, remove the shifter ****, if it is an auto, there is a U-pin in the front that needs to be pulled out, then the shifter just pulls out. If it is a Manual, just unscrew the shift ****.
Lift the armrest cover and remove the 2 screws that hold the shift plate on, also carefully remove the light that is attached to the shifter plate. Carefully pop out the plate.
With the plate off, remove the connectors to the cigarette lighter, power window switches and power mirror controls, if the car has power accessories, if not, then move on to the next step.
There is one screw that is between the shifter and the armrest cover, it's actually really close to the shifter, remove that screw.
In the armrest console, remove the 2 screws that are at the bottom.
Now remove the old center console.
Place the new console where the old one was at. It's easier if you have the shifter plate off of the new console.
Now make sure the console is fitted under the radio pod and line up the 2 holes in the armrest console to the holes in the car and screw the 2 screws in.
Connect the power to the cigarette lighter, connectors might be different, if so, then use the cigarette socket from the old console in the new one.
Now put on the shifter plate.
Now put on your shift ****.
You are now done if you don't have power mirrors or windows.
If you do have power windows and mirrors you will need to find a place to mount them. A few guys have made little plates in the ashtray to mount the controls, I'd recommend doing that. That is where I am at right now, finding a place for my controls.
That should be it.
Old Dec 30, 2001 | 12:22 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Firebreatha's site and nosaint's site helped me some. I don't know the url for Firebreatha's but nosaint's VERY informative site is www.nosaint.ca then go to TRANS and MISC...I think. Have fun.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
Firebird sweden
Aug 16, 2015 05:02 PM
