How to remove 90-92 Gauge Panel.......
Old Feb 21, 2002 | 01:35 PM
BowtieFever's Avatar
I bought new Xenon Hyperwhite 194 bulbs for my gauges and AC/Heater Controls. I need to know how to remove the gauge panel. Any pics would be helpful. Thanks
Paul
Old Feb 21, 2002 | 10:31 PM
Anyone????? I know people have installed whitefaced gauges in these years. I am going to try to do this on friday.
Old Feb 21, 2002 | 10:37 PM
Casey'91Z28's Avatar
To get to the guages you have to take off the panel below the steering wheel it will have 4 torx bolts holding it up. Then to make it easy on you take off the dash there are a bunch of screws on the bottom of it and the four near the windsheild. Unhook your black battery cable then pull out your headlight **** then look from under where there is a little button that will allow you to pull the **** out completely. Now you have to take out the bolts that hold the black cover on, then remove it. Then you just unbolt the guage cluster and pull it out you might have to move your steering wheel around. Hope this helps.
Old Feb 21, 2002 | 10:52 PM
jm91rs's Avatar
the headlight switch will have a button with a spring on it. wiggling the actual cluster out from around the wheel will be the tough part.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
355sbcTPI
Aug 19, 2015 04:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
