Wheel specs
Old Apr 3, 2002 | 06:34 PM
Matt's Avatar
Wheel specs
what are the wheel specs for our cars. I am looking on ebay for an new set of wheels and need to know what size bolt patter, offset, back space or whatever info to determine if wheels will fit.
Matt
Old Apr 3, 2002 | 07:38 PM
Boxeat2469's Avatar
15" rim
15X8 with 4 1/2 inch backspacing front, 5 1/8 backspacing rear. Use tires with an aspect ratio of 55 or less with a section width of 255.
16" rim
16X8 with 4 1/2 inch backspacing front, 5 1/8 backspacing rear. Use tires with an aspect ratio of 55 or less with a section width of 255.
17" rim
17X9 with 5 1/2 inch backspacing front and rear. Use tires with an aspect ratio of 40 or less with section widths of 255 front, 275 rear.
18" (getto) rim
18X9.1/2 with 5 1/2 inch backspacing front, 18X10 with 6 inch backspacing rear. Use tires with an aspect ratio of 35 or less with section widths of 275 front, 275-295 rear.
Note: all cars are not the same. These figures came from the 3/2000 issue of car craft and may not fit your particular vehicle. Use care and caution when installing your tires to assure proper fit and wear patterns
Old Apr 4, 2002 | 07:24 AM
Matt's Avatar
What about the bolt pattern. I know its a five lug pattern but what would the measurement be or are all 5lugs the same?
Matt
Old Apr 4, 2002 | 07:56 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
they are 5 x 4.75" and all 5 lugs are far from the same, there's probably 10 different sizes.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
mrdevontay
Sep 2, 2015 08:04 PM
