In Need Of Serious Help!!!!!
Old Apr 23, 2002 | 12:15 PM
Dmook62's Avatar
Okay I got my IROC-Z last summer. I knew it had some frame damage but now when i got it out of storage to start working on it I noticed a serious problem. The frame is starting to rust really bad and in 1 place under the front door on the pasenger side is a hole in the frame. My 1st ? is how do I repair this damage so it will with stand the force of a nw engine and how do I stop the rest of the rusting? I heard about POR15 but will that with stand serious frame movement? Please Help I dont want to junk the IROC over something like this!
Old Apr 23, 2002 | 01:06 PM
MILT's Avatar
Okay 1st of all, are you positive it is frame and no floorboard? Floorboards usually rust through 1st and can easily be patched--just cut out the bad section and weld new stuff in (or you can go ghetto-style and rivet and JB weld it in...).
If it is the frame, your best bet it to take it into a frame repair shop, unless you do your own welding, then remove bad section and replace/reinforce w/ new steel.
BTW, POR-15 is a great product to control rust. Use it on existing surface rust and nearby areas to prevent rust spread or rust-through. POR-15 cannot substitute for steel frame.
MILT
Old Apr 23, 2002 | 02:52 PM
Dmook62's Avatar
Yes Im sure its the frame I had 1 spot of rust in the passenger floor board but nowhere else that i know. Im good with welding and my dad does it really good so is that all im gonna need to d it weld it?
