Here's a list of what other GM power door lock actuators will fit your car
Old May 13, 2002 | 12:39 AM
Chris Luongo's Avatar
Hey guys, I stumbled across this as part of an eBay auction.
It's not an official GM document or anything, but it could still be useful:
http://cgi.ebay.com/ebaymotors/ws/eb...827725&r=0&t=0
Old May 13, 2002 | 01:05 PM
2vmodular's Avatar
note that while the actuators may interchange, the brackets that hold the actuator to the door may not. such is the case with the chevy s10.
had started to write up an article on power door lock retrofit, but hasn't been finished yet:
http://www.geocities.com/modularmoto...gen/powerlocks
Old May 13, 2002 | 03:54 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
does that come with both or just one? also are the left and right the same thing??
Old May 13, 2002 | 09:03 PM
2vmodular's Avatar
both passenger & driver side door lock actuators interchange.
actuators can and do fail. but often the problem is lack of lubrication, see the page mentioned above for some details on this topic.
are other odd problems that thirdgens have with lock actuators too. for instance, the metal electrical terminals become corroded and don't conduct anymore, can scrape off the corrosion as a temp fix. also, the rivets that hold the lock actuator to the door sometimes become loose causing erratic door lock operation. pull the door panel to check for sure.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BrianI
Aug 9, 2015 11:52 AM
