Lower Door Hinges (Assembly)
Old May 21, 2002 | 09:19 PM
GoldenSwordZ28's Avatar
Does anyone know where to get the lower door hinge assembly for a pretty good deal? The local Chevy dealer wants $84 per side, just for the piece that is on the vehicle side. I really only need that preticular piece (The part with the roller and everything) but, $168 is alot of money for hinges.... welp, if anyone knows a place to grab um at, I'd love to hear about it
ThanX
Adam
Old May 22, 2002 | 05:01 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
So far, GM is the only place to get this "body side hinge strap". This part is attached to the body with three bolts. But the new one only has two holes. You must transfer the location of the third hole from your old hinge strap to the new one.
If this is done properly the door will fit perfectly and need no adjustment. The new third hole must be the same exact size as the old one.
Thanx,ANDYZ28
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
johanlindgren
Aug 15, 2015 08:37 AM
