When is it too much rust?
Old Jun 5, 2002 | 11:27 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm getting some rust under my car. Its starting to spred. I plan on taking it to a body shop to see if the car is worth painting or not. Does anyone have any pics of they're cars w/ rust on them.
How much is too much. I don't want to do the susp. stuff if the cars not going to last very long.
Any help is greatly appreciated. :hail: :hail:
Old Jun 5, 2002 | 12:00 PM
Ergo60's Avatar
I can take some pictures of my rust with some car on it, oops I mean of my car with some rust. I will send them to you tommorow. It is mostly surface rust, and from what I have found in the Classic Industries catalog I can replace any body or floor panel on the car.
Classic industries
It is only a matter of love......
Old Jun 5, 2002 | 12:41 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're in Virginia, I'd bet your car is nowhere near bad enogh to get worried about. A little surface rust isn't hurting anything. It's unavoidable. It's certainly better to nip it in the bud, but it doesn't really get toward the "point of no return" point until you start getting panels that you can start poking holes in. That's when it's too weak to maintain structural rigidity. You should see my sport coupe. You can see the underside of my carpet from under the car.
Old Jun 5, 2002 | 01:46 PM
1982chevycamaroz28's Avatar
if u think little holes are bad i can fit my entire hand thru a hole in my floor board.
Old Jun 5, 2002 | 01:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Go look at my pics in my 1/4 panel message! Then look at http://www.por15.com , and decide what you want to do.
Old Jun 5, 2002 | 02:00 PM
WK Irish's Avatar
Here's an alternative treatment option
Free Bird:
Take a look at Zero Rust as a means of treating what I understand you are finding on your undercarriage, including any and all components there: axles, springs, tranny, floor pans, inner fender wells, engine compartment, etc., etc.
Lots of DIYer's are finding our aerosols or bulk products an easy on the pocketbook, yet very effective means of fighting & maintaining the battle against rust.
Even if you aren't an experienced restorer, or for that matter, if you are, using ZR is not rocket science, doesn't take a modern, thoroughly equipped shop nor an air supplied respirator system to use (whether brushed, sprayed or rolled) and its forgiving nature as to the prep work required, gives it a leg up on most other products that probably will do the job, but at a considerably greater cost in terms of both money and prep work.
Check us out.
WK Irish
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
