keyless entry hatch release
Old Jun 5, 2002 | 08:38 PM
ChickenFried's Avatar
I just ordered a keyless entry system that has a button to open the trunk. I just wanted to know what I am going to have to do to get this to work. I am putting it in my 91 and it doesn't have the button to release the hatch, you have to use the key. Will I be able to use the keyless entry hatch release with this or will I need a different pull down or what? I have an iroc that has the hatch release switch so I can use whatever parts that I want from it but I need to know what I am going to have to do.
Old Jun 5, 2002 | 08:50 PM
88txiroc's Avatar
Your 91 does NOT have a remote trunk release? It should have a button between the window switches. If not, you will have to wire it in from your parts car. I can tell you how to wire the keyless into it, just did it on my car. Thomas
Old Jun 5, 2002 | 09:00 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You can add the standard solenoid to the hatch release. It is just one bolt to attach it. Wire it with a relay to the remote release and you are set to go. You don't need to add a switch unless you want to pop it manually from in the car as well. I added one to my 'vert (they come with a tonneau release instead of a hatch, or in my case trunk release). I put my switch inside the center console to keep it from prying eyes.
Lon
Old Jun 5, 2002 | 09:07 PM
My 91 doesn't have power anything right now. So do I just need a solenoid and a relay. there is a relay directly under the switch, right? Is that what I need to wire in?
Old Jun 6, 2002 | 09:32 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
My 87 bird had power nothing. I added power windows and door locks. Later I wanted to pop the hatch from inside. I bought the factory button. When I removed the gauge panel I found that the wiring was already there for the switch. I plugged it up, but found out I had to add the signal wire once I did the truck release button worked fine. It already had the solenoid and relay back there. Maybe yours is the same.
From there, I had installed a door popper kit and it had an extra input. Its been a few years, but I believe I tapped into the signal wire from the switch and it gave me keyless trunk entry with my door popper remote.
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
