Does that go there?
Does that go there?
Has anyone ever tried relocating the gas filler neck inside their car? I was wondering if anyone out there has relocated the gas filler neck to the inside of the rear glovebox to give the car a "trick" look and shave the filler door for a much cleaner outside.
lol thats nuts.. Especially if your filler cap ever starts leaking or any hoses. Also when i fill up with gas i always drip alittle at the end while im taking it out.. in your case it would just drip inside of the car.. Drips an fumes leaking inside of my car? No thank you
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I haven't done it personally but I've seen it done on some show trucks. They relocate the filler to the inside of the bed under the tonneau cover and shave the filler hole. Looks much smoother!! Wish I had some usefull info about the mod but honestly I dont ... I imagine it would be really hard to get behind the filler there but once you can access the nozzle, work down and cut it. Have someone at an exhaust shop custom bend a filler that ends on the inside like you want and have it welded back on. Something like that I think. Dont forget to run the car dry before welding lol
