Quick Rear Bumper outter skin removal tips, Please!
Old Jul 18, 2002 | 11:39 AM
KED85's Avatar
HI All.
This weekend I have a chance to grab from two perfect rear bumper caps. I only need one, tho
I know about the quick pins at the bottom, about 7 or so.
I know about the 4 verticle nuts and bolts per side panel.
WHAT I DO NOT KNOW IS HOW TO ACCESS THEM
I'll bet I need a 10mm deep socket & extensions.
And rip out any offending interior body panel in the way.
What about the attachment points behind the taillight assembly?
Are they like the outside bottom, those pin type things you attack with nibblers & a flat edge screwdriver.
Thanks for the quick rear bumper cap relaese trick tips!
I have a choice of three perfect front driver fenders, too!
Still looking for that front bumper nose cover!
Old Jul 18, 2002 | 08:26 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
well not to burst your bubble but you have to take the taillights out to get access to the ones under the lenzes..also the rear license plate bracket has to come off as well...once all those are off it just slides off(providing there isnt alot of rust holding it on)
good luck
iroc2nv
ps..dont think this will take you 5 mins....more like 30 mins..maybe more
Old Jul 18, 2002 | 09:44 PM
KED85's Avatar
Tailites easiest part.
Zip nut/wing nuts.
Thanks for the tips!
It'll be hot so I wanna be done quick.
How is the license plate area attached?
Are the attachment nuts behind tailites-bumper the same type of zip plastic pin nuts as under bumper facing the ground?
Old Jul 19, 2002 | 03:07 PM
iroc2nv's Avatar
Axle/Gears: 3.45
license plate nuts are 10mm same as the whole car, and under the tailights is those things you use a gar nose pliers to get ahold of then pull out..
good luck
iroc2nv
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
