I think i will prime my car what is involed in it? I mean what should I look for in a primer, how should I prime the bumbers, do I need to use a flex agent? Should I sand down the origanal paint to bare metal or just scuff up the surface? Should I buy a sealer primer? Sould i spray it on with a gun or brush it on, or even use a can. Iwant to do this right the first time so i dont have to do it again. I need answers fast.
this all depends on what kinda of paint job you going to do. Use a sandable, filler primer and fine grit paper. For small spots with minor abbrasive imperfections use spot glazing putty. I'd use ppg or dupont. Or, if you're going to use spray cans, use several thin layers. Try some krylon.Good luck, and slow down on your typing,I could barely make it out.
:rockon:
:rockon:
