Help! Paint Problem - Peeling paint under primer
Old Sep 25, 2001 | 03:52 PM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
I am preping my vehicle for paint and have run into a problem. I am priming the entire vehicle and after spraying the first coat, I noticed the paint underneath began to bubble in one particular spot. This was a spot that the paint had originally flaked off so I sanded the area to smooth the edges and sprayed the primer to cover. The edges of the original paint were peeling so I sanded again and reprimed. Now same problem over a larger area. I didn't learn so same thing again on an even bigger area.
What is happening. I peeled the paint off down to the original factory primer (it came off easily with the primer) but it continues to peel around the edges every time I reprime the area. This didn't happen in other areas with similar problems. What could be happening and how do I fix. Should I sand it down to the metal and use etching primer? How do I keep the edges from peeling?
I've done this type of work a few times and never had this problem. Any advice is appreciated.
Old Sep 26, 2001 | 10:48 AM
Engine: 5.7L TPI
Anyone??
Old Sep 26, 2001 | 12:12 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You need to use an epoxy based primer or sealer. I ran into the same problems on my GTA because of the laquer-based primer. The primer would cover the feather-edges, but the new paint would eat right through the primer and lifted my paint. I'm in the process of repainting the whole car now. I was told buy other members here and other places that the cure is to use the epoxy-based sealer, and so far in our tests, it seems right-on.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 26, 2001 | 01:45 PM
Engine: 5.7L TPI
Thanks for the help Jim85IROC. I'll pick some up and give that a try.
Old Sep 27, 2001 | 11:11 AM
Cityboy's Avatar
Are you going to remove rust in the T-Top area? I need to perform that, but need a total lsit of materials needed. Any of those rust preventers any good?
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
neekolzun
Aug 24, 2015 04:59 PM
g.l.mos
Aug 22, 2015 12:02 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
