how do I get the bulbs behind the speedo out.
Old Aug 22, 2002 | 02:20 PM
5SIZ's Avatar
Car: 1987 IROC-Z
dont know if I should have posted this in electrical but anyways, I need to replace a burnt light right behind my speedo gauge, but it doesnt un screw like the others do, how the heck do I get to the 194 bulbs behind the speedo???
Old Aug 22, 2002 | 07:29 PM
Jza's Avatar
Jza
Leave the gauges in. Take the whole cluster housing out (the white plastic piece). It's only held in by two 10mm nuts and the speedometer cable (once you remove the faceplate et al.)
Once you can see the backside of the housing, you'll see that the bulbs are actually 194s with an integrated plastic socket that is not removable. They have to be replaced either as a unit, or the empty sockets must be bought and regular 194s can plug into them.
See the little grey deals? They come out with a half-twist.
RedLeader289
May 28, 2019 01:47 PM
mattcanty
Oct 12, 2015 11:08 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
