wheel spacers strength?
Old Aug 28, 2002 | 03:56 PM
toddlsf's Avatar
I've got to use about an 1 1/2 inch or 2 inch spacer on my rear wheels. How strong are they? I'm putting 275/40/17 nitto drag radials on the car. It should run 12's or so.
Thanks,
Todd
Old Aug 28, 2002 | 04:42 PM
FLYNLOW92rs's Avatar
I've heard of the bolts comming loose, but never of a wheel spacer breaking because of HP......
Remember that you have 10 lug nuts so they have a tendency to come loose easier.......if not checked before races and tightened to the correct strenght........
Old Aug 28, 2002 | 04:56 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
As long as you have the proper lugs and good billet spacers I don't see them breaking. I've not had a problem with mine in 3 years.
Old Aug 28, 2002 | 05:56 PM
SSaudio's Avatar
mine are doing fine, i've had them on five months now.
Old Aug 28, 2002 | 08:21 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Mine don't give me any problems.
Old Aug 28, 2002 | 10:56 PM
jawzforlife1's Avatar
mine are fine (normal street use), just do what was said above. If you are racing with them, check the lug nuts before using.
Old Sep 2, 2002 | 05:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I heard somewhere that you are not supposed to run spacers on the drive wheels at the drag strip. Not sure if that is true or not.
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
