Rims Need Cleaning
Old Sep 21, 2002 | 10:32 PM
prostockdr's Avatar
Rims Need Cleaning
THe finish of the rims is very bad it is breaking down and it needs 2 be restored to its original. For the most part they to be cleaned what kind of cleaner would you guys recommend for restoration of the Rims. which will bring back close to 100% finish of the rims.
thank you
Old Sep 21, 2002 | 10:51 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
If it's breaking down the way I'm thinking, there really isn't a way to 100% bring it back. If the clear is turned yellow or cracking, you're best bet would be removing the clear, and polishing. There are some good threads about polishing rims by doing a search. I polished mine on my 92 and I'm completely satisfied with the results I got. It was alot of work, but well worth it.
Old Sep 22, 2002 | 03:45 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
im in the process of refinishing my rims right now, it takes a long time..i took them off the car and got them cleaned up with a wire wheel then the inserts that were painted from the factory i primered and painted gunmetal grey, then around the edges and on the spokes i polished them with rubbing comound...still needs some touch up work but looks a whole lot better.....takes about 8-10 hrs a wheel if you take your time like i did..
Old Sep 22, 2002 | 04:29 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Old Sep 22, 2002 | 04:48 AM
karrlives's Avatar
Rim cleaning
Just get some kind of all purpose Rim Cleaner and Just SCrub SCrub and scrub till its clean then use some kind of Finisher ...
cya PRO Stock DR.
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
