Painting the underside of a fiberglass hood
Old Sep 23, 2002 | 06:58 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Has anyone done this? I am in the middle of painting the engine bay and i figured i might as well paint the hood too. Is there a certain way i should do it being that it is fiberglass or no? I would sand it down first, put on primer, fine sand it, spray it with the paint, and then spray with clear coat. Does anyone have any suggestions, thanks.
Old Sep 24, 2002 | 09:15 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
The cowl hood on my 86 Camaro was from Unlimited Products. They finish the underside smooth except for a square in the very center, which looked like chopped fiberglass. I painted the underside to match the car, and then sprayed flat black undercoating on the part that was unfinished. It turned out really nice and ended up looking kinda like the factory hood liner.
Hotrodboba400
Dec 10, 2019 07:07 PM
snakeshooter
Sep 7, 2015 11:15 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
