Anyone have a 5 speed and 4th gen console??
Old Oct 13, 2002 | 05:14 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
Just wanted to see if they work and line up ok since I know the T56 shifter sits back farther. Thanks everyone!
Old Oct 13, 2002 | 07:58 PM
89Irocz23's Avatar
yeah just use the 6 speed shifter plate and it works fine.
Old Oct 14, 2002 | 11:45 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
is that possible
Old Oct 14, 2002 | 09:41 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Yeah it doesn't even look like its 2" off (which in reality it is). Except for the switches (which still aren't done, slow me) the console def looks like it belongs there
Old Oct 14, 2002 | 11:50 PM
jocww's Avatar
give us pics
Old Oct 15, 2002 | 09:48 AM
Car: '89 TA
Engine: LB9
Transmission: M5
jocww:
I'll try to comply w/ that ASAP for you guys. Its about time I took pics of the console ayway, finished or not.
Old Oct 16, 2002 | 10:37 AM
jocww's Avatar
yes like now
Old Oct 19, 2002 | 05:59 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Sorry for the wait:
Old Oct 19, 2002 | 06:01 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Any further questions welcome As you might be able to see, I still have to cut the front tabs out more, and obviously make a panel for the power window and mirror switches.
Old Oct 19, 2002 | 06:06 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
Cool, thanks dude!
Old Oct 19, 2002 | 07:26 PM
jocww's Avatar
do the holes line up? how long did it take you? what else did you have to modify? give me some directions please. also would it also work with a camaro? does it matter if i get the 4th gen counsul from a firebird because i have a camaro or does it not matter. thanks
Old Oct 19, 2002 | 07:50 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Jocww:
-It only bolts in by the rear 2 holes inside the compartment, and yes they line right up. The original console has 4 bolt holes. I don't have any problems with it being loose
-The actual installation took me MAYBE 10 minutes. About six minutes to take out the old console, 4 to put in the new one.
-What I've modified (or in the process of) are the cigarette ligthers and the hole for the switches.
-You can prolly hardwire the lighters (2 of them) into the existing lighter circuit, but I am trying to aquire the correct plugs for them to make taking the console (for whatever reason) out easier.
-The window and mirror switch plate is what is taking so long. I want to get it perfect
-As long as you get a console that's from 98+ I think you're fine. I would go by appearance actually just to be sure. If you find one that looks exactly like mine then you're good to go.
-As for the camaro thing, you're going to want to do a search, there's 3 or MORE topics on this already. The radio portion of your console will have to be cut into b/c it is ONE PIECE. The camaro aspect is definitely not my area of expertise for this install.
EDIT: Bad406Z: no prob!
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
