Cowl Induction hood questions
Old Nov 3, 2002 | 04:42 PM
Jaboski's Avatar
Car: 91 Firebird
Axle/Gears: 3.08
I just bought a 2" harwood fiberglass cowl induction hood. Its used though. There are 6 holes in it for pins i guess. I was told that i cant put pistons on it to lift it up, so i have to lift the hood off whenever i do engine work. Is this bad/illegal? How would i fill those extra holes in, and how many pins will i need, i just bought a pair of locking pins. And this thing isnt going to lift on while im driving or anything righ!?!?!
Old Nov 3, 2002 | 06:16 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i suspect bondo would do a decent job of filling the holes if you apply it right. there's gonna need to be a pair (2) of pins in the front corners and another pair (2) in the rear corners. I've never used the locking pins, but i was told that they are prone to breaking and there's a warning in jegs and summit and on the package they come in that they're not to be used as the only method of securing the hood. If you insist on using them, i'd use them at the back corners and use standard pins upfront. Good luck...
Old Nov 3, 2002 | 07:25 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If it will bolt to the stock hinges, you can leave the pistons off, or maybe use one 'worn-out' piston to hold it open. You don't want too much pressure on it because it may not be braced in the hinge area and would be prone to cracking.
Pete
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
LittleFranks
Aug 20, 2015 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
