!!`-Warning-`!! For all those who want Power Windows
Old Nov 11, 2002 | 04:49 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
If you install them yourself
You will end up looking like this...
Attached Thumbnails !!`-Warning-`!! For all those who want Power Windows-rippeduphands.jpg
Old Nov 11, 2002 | 07:38 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Ouch! No gloves?
Old Nov 11, 2002 | 08:51 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Come on now, suicide is not the way out. Especially with a butter knife! Just kidding . Gloves are highly recommended in doing anything with the windows. I found out the hard way also.
Old Nov 11, 2002 | 09:52 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
been there done that. I did get a little more blood though. Swapping Actuators also does this to your hands/arms.
Old Nov 11, 2002 | 10:59 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Geez, I can't wait to replace my power window motors now
Old Nov 11, 2002 | 11:49 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
I still have a scar on my arm from fixing my lock actuator, like three years ago. 3rdgens are the automotive version of the hamburger helper helping hand
Old Nov 11, 2002 | 12:11 PM
Car: 1987 GTA
Transmission: 4L60e
LOL
Old Nov 11, 2002 | 12:54 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I couldnt' wear my gloves, casue the parts were to intricate.
I had to take them off.
I tried everything, I still ended up with cuts....
Oh well.
At least it's fixed.
Old Nov 11, 2002 | 10:46 PM
88IROCARMY's Avatar
This one is for you,,, Good Job.
Attached Thumbnails !!`-Warning-`!! For all those who want Power Windows-med_34.gif
Old Nov 11, 2002 | 10:57 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Thanks, I need a couple more thoe....
Old Nov 12, 2002 | 12:29 AM
FLYNLOW92rs's Avatar
aaahhhhh...............Manual windows.............I bet they roll up faster then the power windows too......
I was gonna install power windows till i realized the motors are horribly bad......
Old Nov 12, 2002 | 12:49 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
That right there is why I went with the SPAL conversion kit over putting in the power acuators. I'll replace the kit a dozen times before I go after anything inside the door.
Old Nov 12, 2002 | 01:05 AM
zer0321's Avatar
Yep...I know how that goes.....that's exactly how my arms looked after installing power windows in my RS....it was worth it though!
when I installed mine, I tried wearing gloves and they got ripped apart!
it only took me $50 and 16hours (and much swearing as you can fit into that much time)....and I still don't envy doing that swap ever again!
Old Nov 12, 2002 | 01:26 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Man, I'd say your hands look pretty good compared to mine after I changed my starter for the first time!
Old Nov 12, 2002 | 07:00 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
I've got money saying your hands looked better after your first starter swap than my head and face did after my first starter swap.
Old Nov 12, 2002 | 08:08 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I used to get more damaged than that every time I changed my plugs until I finally pitched that POS aluminum plug wire looms I had.
Old Nov 12, 2002 | 10:57 PM
2vmodular's Avatar
My power window retrofit project took a good chunk of time too.
Suspected that all i'd need for parts were the regulators, wiring, switches and miscellaneous mounting hardware but wasn't positive. Could not get a definite answer out of anyone on the boards at the time about what parts i'd need either.
Also had the fun of removing the drivers side power window regulator after I inadvertently installed it inside the passengers door.
If anyone else is considering adding power windows to their ride, take a look at the tech article I wrote first:
http://www.p71interceptor.com/thirdgen/powerwindows
Old Nov 12, 2002 | 11:09 PM
2vmodular's Avatar
You're very correct about window motors giving problems in older thirdgens, that's why I recommend that you replace the motors with new ones before you install the regulator assemblies inside the door. Aftermarket motors are around $50/each. Changing the motor is easy when you can stick the entire regulator in a vise on the workbench, it's not such an easy task when the regulator is still inside the door though. Another trouble point is the switches, but these are around $15/each new at the dealer.
Cranking the windows gets old rather quickly if the car is the daily driver. Another thing that gets old is having to hold the power window button while the window is moving. Now, I've got "one touch" windows in the bird, just quickly tap the button once and the windows will roll fully up or down. Sort of like the fourthgens have except on both windows and in both directions. No need to hold the switch.
Old Nov 13, 2002 | 02:25 AM
zer0321's Avatar
I used 2vmodular's tech article...it was great...everything was really clear and precise.
:hail: 2vmodular
Old Nov 13, 2002 | 10:11 AM
dejavue's Avatar
I guess this is where i'm thankfull I have small hands hehe I replaced the window motors and the lil black plastic things at the front of the windows beside the mirrors. 1 single scratch...I couldn't get the mirror adjusting thing off
Old Nov 13, 2002 | 01:09 PM
VampireHunterC's Avatar
Well...that's how my hands and arms usually look after putting in some wrench time... Still have the scar from changing the starter in my old Escort... fortunatly, I managed NOT to drop the Camaro's starter when I was replacing it...
Old Nov 13, 2002 | 03:33 PM
KlayBuRn's Avatar
Dude my power window conversion was easy in my old RS...we just took off one of the tracks, 2 bolts, popped all the rivets, puts bolts back in, and was done, prolly less than 30 minutes from taking off the door panel to putting it back in...dropping that track, the regulators just pull out or push in!
Old Nov 13, 2002 | 11:51 PM
CaysE's Avatar
Hahaha! Those starters are damn heavy and next to impossible to maneuver into place. The thing fell on my head once, and my arms a few times.
Old Nov 14, 2002 | 01:59 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
ouch .... when we swapped a motor out of my friends 4th gen z28 my hands looked a lil worse than that almost had to get stitches on my finger .... that metal is freekin sharp!
Old Nov 14, 2002 | 10:10 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
when i was putting my stock exhat back on the hold cat back system at the Y pipe fell on my head and smushed it beterrn the heavy *** pipe and the cemet driveway... now that hurt.
Old Mar 26, 2003 | 12:48 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
How can you tell which is drivers side regulator and which is passenger side?
Old Mar 26, 2003 | 06:56 PM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
i put power windows in another camaro. i cheated a little tho. i just replaced the doors
Old Mar 26, 2003 | 08:35 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Ouch guys.
I guess i'm the only one that hasnt been malled by thier thirdgen yet. LOL When I adjusted my windows to seal real good I didnt even get a scratch.
Old Mar 28, 2003 | 11:03 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
lol try doing a new clutch, with 90 weight oil in your hair, arms pure black or the spark plugs, i think my arms were more cut up than that after plugs and plug wires
Old Mar 29, 2003 | 02:41 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
I just got done switching to power windows (its 2:30 in the morning) and it only took me 8 hours . I have to mount the switches still though, so that will make it about a 10 hr project. And my hands are torn to s***. I look like I was mauled by a butter knife or sumthin.
I have a question though...I need to find a way to get power to my switches and 2vmodulars tech article said use the pink or red wire from the fuse box...but there are lots of red and pink wires on my fusebox...which one do I use? There is only one BIG red one, and I tryed to pull it out, but couldnt get it, and I really dont want to break my fuse box...can anyone help?
Old Mar 29, 2003 | 08:37 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I did the swap last year.. and my hands didn't look like that..lol.. though I need to change the driver side regulator this year.. I agree the motors are a bit slow.. but I'm going to see how hard the motor units come apart.. perhaps I can replace the motor with a faster one.. .. or perhaps a motor from a different manufacture could be made to fit.. Though the gear would be a problem.
Old Mar 31, 2003 | 08:25 PM
-N-'s Avatar
-N-
Car: 1984 Berlinetta
Got ya
I have you all beat! Actually my brother...he almost lost a finger working on his 3rd Gen. See we were late for school and it wouldn't crank so he told me to crank it so I tried a few times....to make a long story short you know that "CAUTION FAN" sign...it's because of people like him that it is there.
Old Apr 1, 2003 | 02:06 AM
3rdGenBlackBird's Avatar
How do you do that? That is what I really want.
Old Apr 1, 2003 | 02:13 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
It's an add on module. You can get them on ebay for pretty cheap.
Old Apr 1, 2003 | 02:26 AM
Odyssey's Avatar
Yep. 20 bux for the cheap version that only does it in one direction or 60 bux for the nice version that does it in both directions
Old Apr 2, 2003 | 07:59 PM
Mark W. Winning's Avatar
LOL, I think the only thing that could have cut up my hands more than the power window swap was when the spring on the regulator came loose!
I also used that article and it saved me a lot of problems. Thanks for a great write up.
Mark
Old Apr 2, 2003 | 08:08 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Post form the dead...
Kewl.
Next Time I'm paying the $60 bux to have the new motor put in....
Old Apr 2, 2003 | 09:49 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
Re: !!`-Warning-`!! For all those who want Power Windows
i work on power windows daily, and dont have that problem.
thanks
Old Apr 3, 2003 | 04:53 AM
What would I search for on ebay to find those one touch switches? I tried a few things but didn't come close.
Also, would it be easy to use cheap simple toggle switches from radioshack or something? Would the ones that stay in the position you switch them into work? I don't mind having to switch them "off" when the window stops moving. (At least for now... $60 is too much for me at the moment.)
Old Apr 3, 2003 | 11:33 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
GM power window switches on ebay http://cgi.ebay.com/ebaymotors/ws/eB...&category=6775
Old Apr 3, 2003 | 02:57 PM
Viking's Avatar
Car: / 89 IROC /
I don't beleive your from Hawaii, not tan enough.
Old Apr 3, 2003 | 09:32 PM
  #42
joezero's Avatar
Car: See pic above
Engine: Too Small
Re: Re: !!`-Warning-`!! For all those who want Power Windows
I tanned more in 10 minutes in a tanning booth than I did for 7 days in hawaii. Not everybody there is tan.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
