Help, Replacing the nose and the rear bumper, how to?
Old Dec 11, 2002 | 10:39 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Ok, i'm totally lost when it comes to this kind of work, but after two accidents, this is what needs to be done. Doing it myself would save me a couple hundred dollars in body work, as I would only have to have one dent repaired, and the parts painted.
Can anyone tell me how to take off that nose piece, and the rear fender. I'm guessing, take out the headlights, then just pull out ever bolt you can find that is attached to it? For the back, just unbolt everything? Also, how do I get that rear taillight cover off. Thanks for any help.
Old Dec 12, 2002 | 01:14 AM
CR-SuperChevy's Avatar
buy some "tools" crawl under there unbolt everything until it comes off and your set...
Old Dec 12, 2002 | 10:29 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I don't know if you have a Camaro or a Firebird, but on my '83 T/A, there were 4 or 5 (I think) bolts under the hood between the headlights and then there are like 4 bolts on each side where the fender meets the nose. I had to crawl underneath the car to get to those. I've never taken off the rear bumper, so unfortunately I can't help you there.
Old Dec 12, 2002 | 10:38 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It all depends... is it just the bumper covers that are damaged or are the bumpers itself bent?? If it is just the covers you are replacing, then it isn't all that hard to do. The rear bumper cover ,you will have to remove the taillights and take out the rear interior panels ( spare tire cover and the locked storage are cover.) There are 4 nuts on both sides that need to be reomve from inside the car in those two places mentioned. Other then that I think it is just the plastic pop in clips on the bottom that are left to deal with, and a couple of bolts on the top. Same goes for the front. There are 4 bolts on either side that bolt the cover to the fenders. I don't think you need to take out the head lights though. But again it is mainly the plastic pop in clips, and a couple of bolts. If I got anything wrong here someone will correct it, but I think you'll do just fine.
Hope this helps?
Keiran
Old Dec 12, 2002 | 07:38 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Thanks for the help peoples. I get the peices on saturday, isn't taking things apart great?
Old Dec 12, 2002 | 08:01 PM
deadtrend1's Avatar
putting things back together is the hard part ...
Old Dec 12, 2002 | 10:29 PM
Rage13's Avatar
Car: 89 Firebird
make sure to lable where all the parts went... after swaping my interior i still have a large handfull of screws, everything went back together and stays in place but i still can't figure out where they all go.. on the bright side the car is about a pound lighter now
Old Dec 13, 2002 | 06:16 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
now if i only remembered what skrews go where on my dash and all the interior panel i would have my car together
Old Dec 13, 2002 | 02:48 PM
Rage13's Avatar
Car: 89 Firebird
how far off are you from having everything back together? if you need any little parts or screws let me know, i mite beable to help you out
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
