WIndow Help
Old Dec 17, 2002 | 04:07 PM
jdrafke's Avatar
WIndow Help
Hi, i Have a 92 rs camaro and it has a problem with the passenger side window sealer. for some reason the window has a like little gap and air seeps in the side. my buddy has a 92 and it is the same does anyone know some fixes for this
Old Dec 18, 2002 | 04:24 AM
Fade00's Avatar
I have the same problem. You can see a gap between the glass and the weather stripping. It's especially bad on the passenger side, where you can stick your whole finger out of it. Plus it makes an annoying whistling sound from the air seeping in.
Old Dec 18, 2002 | 11:39 AM
bradkeith's Avatar
That is easily adjusted from underneath the door panel. If you take your door-panel off you will see three bolts up on the very top of the door that adjust the glass. Once the door-panel is off, it's pretty much self-explanatory
Old Dec 19, 2002 | 01:21 PM
85yellowiroc-z's Avatar
New door pins would be a great idea!
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
