bumper question
Old Dec 31, 2002 | 08:48 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
bumper question
hey, i have a crack in my front bumper so im getting a new one, i have an 88 iroc and a guy will give me one off of a sport coupe for cheap...if i take the louvers off and add the spoiler, will it be exactly like a iroc bumper? i just wanna make sure it will be perfect when its done...thanks
Old Dec 31, 2002 | 09:00 AM
MILT's Avatar
Can the crack be repaired? I have fixed some nasty cracks and gouges w/ stuff called SEM urethane repair something or other.
MILT
Old Dec 31, 2002 | 06:28 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
really?...could i have this done at a body shop? sounds like a good option, the crack isn't really bad. hm...
Old Dec 31, 2002 | 06:36 PM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
hey reid u can fix that bumper man. when i tanked some old ladys car i cracked my bumper. i got a new one but i fixed the other one for my 88. its an easy fix. just tedious to get the surface perfectly smooth for primer and paint
Old Dec 31, 2002 | 06:57 PM
1 bad z's Avatar
yes u can fix the cover, take it off the car put a bead of a product called panel bond on each side of the crackand fiberglass it from behind to reinforce the crack(use the fiberglass mesh and resign system)then wipe off the excess panel bond from the front of the bumper and let it set up a few hours..then use a product called duraglass on the front of the bumper(its like bondo only stronger)sand that smooth then u can put a skim coat of half lite(light weight body filler)and finish sand that after u prime it then speckle spray som flat blk paint on the area this will help u find low or high spots when u do the final block sanding on the bumper(if u leave any black specks u have a low spot there,,if u take it off in one area u have a high spot)after that u will be ready for paint,,,mike P.S. when u do the speck;e paint u will be wet sanding the bumper about 500 grit paper,,hope this helps
Old Jan 1, 2003 | 12:48 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
hey, thanks a lot for the help guys!
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
mikey8494
Aug 22, 2015 07:57 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
