What size nut driver to use??
Old Feb 4, 2003 | 12:29 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Guys, when pulling the front cover off the cluster, it's held on by those torx head screws. But once you get that off, the plastic clear sheet over the gagues is held on by real small hex head capscrews. What size nut driver for those? 5mm? 4mm? Thanks!!
Old Feb 4, 2003 | 03:45 PM
scauffiel's Avatar
Forgive this obvious way of looking at things... but why don't you do what I do:
1) Try driver
2) If it fits - voila! If not, repeat step 1.
S.
Old Feb 4, 2003 | 05:45 PM
Tremo's Avatar
Because I don't have one that small. I want to know what I need to go out and buy. Every one I have is too big.
Old Feb 6, 2003 | 10:49 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Try 7mm.
Old Feb 6, 2003 | 11:11 AM
Tremo's Avatar
Thanks, but since 6mm was too big, it's gotta be smaller than that. I've been told it's 5.5mm.
Old Feb 6, 2003 | 01:20 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I've never seen half sized metric sockets. If a 6 mm is to large and a 5 mm is to small then try an SAE socket.
Old Feb 6, 2003 | 02:29 PM
bradkeith's Avatar
There is a 5.5 mm socket, but i don't think that's it. Let me go into my garage and check out my socket rails and my spare cluster real quick.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
69 Six Pack
Oct 5, 2015 07:51 PM
knight72
Aug 10, 2015 09:32 PM
