power window stuck help
getting out of my 91 rs at white hen with the drivers side window 2/3's of the way down i shut the door and noticed a weird noise (not the regular door closing noise) after that i could not raise or lower the window, nor could i pull it up or push it down by hand. what happend? did i mess up the motor? the passenger side window goes up and down normaly.
Car: 85 Camaro SC
Engine: V6
You may need two people for this, but have someone push up on the switch while you pull the window up. If that doesnt work then pull off you door panel to see if anything is jammed in the gear track.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
