can you get to the small area of the rear quarter below the body side molding above the rocker panel from inside the car ? that area is dented inwards on the 88 bird and i want to repair that in a month or less. what about rear of rear wheel arch also at same height(about body side molding height) ?
thanks for anything
thanks for anything
Is the dent severe? Is there paint damage? If not, get a paintless dent removal person to give you an estimate. These are accessible and the dent might be fixable without worrying about paint match. It might cost less than $100, also, depending on the dent size.
pretty good dents wuill need to be pushed or pulled out, paintless dent removal will not do it, paint is damaged, need massaging of the metal to fix it, i really nweed to know if i can get to back side of these areas from inside the car, someone has to know
thanks
thanks
