Is this strong enough to hold floor pan patches?
Old Mar 15, 2003 | 03:03 PM
84 Challenge's Avatar
Check this stuff out! Was thinking about this stuff to patch my floor pans. Using this instead of welding (which I don't have access to). Should I?
http://www.imperialrestoration.com/p...ust_repair.asp
Old Mar 15, 2003 | 06:06 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
No. Go to a local autobody store and get metal adhesive. It's made by 3M, Lord (Fusor), Duramix, and Kent. It's stronger than a weld. If you glue two pieces of sheet metal together, and try to pull them apart, the sheet metal will rip before the glue joint will.
It's not cheap and you will need a special "caulk" gun to apply. Hopefully you could borrow/rent one from the store.
http://www.chevytalk.org/threads/sho...b=5&o=&fpart=1
Good luck!
Old Mar 15, 2003 | 07:19 PM
Good luck!
That sounds like a pretty good idea. Looks like the entire floor of the car will be made of patches, 'cause I keep finding holes.
Brandon
Lanz06
Sep 14, 2015 07:16 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
machinist21
Sep 5, 2015 03:03 PM
mrdevontay
Sep 2, 2015 08:04 PM
