Going to drill into parking lights...will I have a problem with fog??
Old Mar 16, 2003 | 12:51 AM
CamaroX84's Avatar
I will be installing a set of strobe lights on my 84 Camaro sport coupe. I'm putting them into my front parking lights. Remember on this model the lenses are solid orange, not clear, if that even makes a difference. I will be drilling a 1/2" hole in the back of each lens. The strobes do come with a rubber grommet on the base of each light. Will I need to worry about the lenses fogging up since there will be holes in the lenses, and they probably won't seal perfectly? I don't want to use RTV if I don't have to. But if I do I guess I will. Any suggestions? Thanks in advance.
Old Mar 16, 2003 | 07:05 AM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
you might want to try it without the sealant. if it does fog up just wait till it dries and then put clear silicoln on it.
Old Mar 16, 2003 | 12:07 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
dude ur from grayslake?!? thats sweet where at? im in wildwood on gages lake, right down center st. i put gurnee in my profile cuz i thought people would recognize that name better.
Old Mar 16, 2003 | 12:10 PM
Car: '86 IROC
and you work at ace?!?! im trying to get a job there!! this is way too weird:lala:
Old Mar 16, 2003 | 03:56 PM
dsaint1347's Avatar
I install strobe lights for a living (police, fire etc. ) and from experiance you have to make sure you do not have any moisture in the lens before you install the strobes. Another tip is to not touch the glass part of the strobe and as extra precaution I always seal the bulb with silicone.
Old Mar 16, 2003 | 10:00 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
if you slit the bumper under the drain hole area on the parking light, they will not fog up. this was gm's fix for the problem. the bumper cover holds moister (water) up agianst the drain hole of the parking lamp and then the water gets in and "fogs" up the light.
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
TheExaminer
Aug 26, 2015 04:59 PM
