Ah, Anyone like Sport Comp Gauges?
Old Apr 23, 2003 | 08:44 PM
  #51
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: We drove it last night. Only problem we have now is the oil leak from the crank seal.
Originally posted by SydwayzTA 86
Might wanna try replacing the Oil Pressure Sending Unit, had the same problem on my 86 t/a so i replaced that and poof, no more oil leak
Naw, the leak is from the crank seal in the timing cover. Oil Pressure sender is perfect.
Old Apr 23, 2003 | 08:45 PM
  #52
Zepher's Avatar
Originally posted by TransAm12sec
Wow thats incredable. Just to make sure, are these the gauges you used? Tach and Speedo.
Do the gauges rattle?
oh, do you if its a good idea to convert from electric to mechanical and vise versa?
Yep those are the same guages. Nope, no rattles yet from them. We have them mounted pretty tight, was kinda hard getting the dash back together.
  #53
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Ah, ok. was just a thought, by the way, havnt seen you on Aim for a while, been busy ?
Old Apr 24, 2003 | 01:44 AM
  #54
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Gotta say kudos to autometer, the gauges are pretty accurate, well as accurate as the ECM is anyway.. we had it up and monitoring with my laptop while the car was on the interstate and they are as on to the degree as they can be..
Old Apr 24, 2003 | 01:53 AM
  #55
Zepher's Avatar
Yep, been really busy with these LT1 swaps. 8-12 hours a day on most days for the past 2 months.
Old Apr 24, 2003 | 11:17 AM
  #56
Car: 1986 Trans Am
Engine: 5.7L TPI
Cant wait till that baby's done gotta have a go with her
Old Sep 11, 2005 | 12:00 AM
  #57
Bddbrd86's Avatar
Car: !986 Firebird
Transmission: th350
Here's a pic of my Autometer set-up in my 86
Old Sep 11, 2005 | 04:07 AM
  #58
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Looks very nice.
I'd really like to have the Sport comps, but it just doesn't seem worth the cost right now.
What are the details on your setup Bddbrd86?
This is a good post from a while ago, I'm sure many people haven't seen it yet.
Old Sep 11, 2005 | 11:13 AM
  #59
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
looks awsome guys!
I personally would have used the ABS plastic over the whole pane just so it looked the same texture and stuff, but it still looks incredible! I cant wait till I get some $$$ so I can re-do my whole interior. I've got big plans as far as the gage panel goes :-P
Right now mine looks OK but its still very rough. (and I've got AutoGage gauges, too poor to buy the REAL stuff :-P lol j/k)
Old Sep 11, 2005 | 12:07 PM
  #60
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
The setup still works great.. though I am putting the car on the stands for a year to work on it again..
It was sort of a had-to-do thing, no really good gauge options for 82/83 birds..
Old Sep 11, 2005 | 12:49 PM
  #61
admrlam's Avatar
J,
The gauges look great in there. Just curious, have you thought about using the router on the dremel to put the groove around the ABS to match the existing dash pieces around the tach and speedo? Or maybe sanding down the diagonal corners like the existing too?
Just a thought, to try and match the rest of the dash as well. What did you do about the Idiot Lights that were in those gauges? SES light and such, just disconnect them? Or do you have plans to hook them up to lights somewhere else?
I might have considered staggering the gauges in an up down up down pattern, but i love the way they came out nonetheless...
Old Sep 11, 2005 | 01:20 PM
  #62
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
the corners on the plate were rounded off, cutting them diagonally would be hard since the bolts are not for show they are also holding in the gauges..
I have no belt, brake, etc idiot lights, for the turn signals I simply kept the printed circuit that went to the signals and hacked away the rest, it works fine..
for check engine, it came with my speartech harness with the LT1 so it is actually down by the pcm port..
All in all the only thing I will change on the next buildup is change the order they are in, the temp gauge is partially blocked by the steering wheel..
Old Sep 11, 2005 | 04:56 PM
  #63
admrlam's Avatar
Gotcha, i didnt lean cut the corners off... Looking back at the top pics, it loiks like the corners are the same height as the rest of the plastic, it just as that routered groove around it.
I like it nonetheless...
Old Sep 11, 2005 | 07:27 PM
  #64
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
looks good Zepher. Here's mine, I didn't want it to look like some Autometers added to factory panel though ( no offense)
Old Sep 11, 2005 | 11:15 PM
  #65
Bddbrd86's Avatar
Car: !986 Firebird
Transmission: th350
Mine has the speedo and tach mounted to a 1/4 MDF board that was attached using the factory screw studs. I then had to use the spacer in the middle of the factory set-up to fill in the gap between the board and the benzel. I laminated a piece of formica to the front of the benzel. I made the holes around the speedo and tach a little bigger thn the benzel to give it a cleaner look. For the turning signal I just cut a rectangular hole where the factory ones were and mounted some lights in the spacer part where they would have gone in the factory set-up. The smaller guages on the side have angled trim rings which aim them to the driver. Since I not running a computer set-up I didn't need a check engine light but I mounted a 1/4 red light that is wired to the brake warning system.
Old Sep 11, 2005 | 11:17 PM
  #66
Bddbrd86's Avatar
Car: !986 Firebird
Transmission: th350
Here's a pic from the other side.
Old Sep 12, 2005 | 12:27 AM
  #67
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i like my sport compe guages.
Old Sep 12, 2005 | 09:19 AM
  #68
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Here is my set up.....phantom guages.
87v6Bird
Jul 1, 2018 04:12 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
Jorlain
Oct 8, 2015 01:57 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
