Repair for door llock cylinder hole?
Car: 89 Firebird Formula T-Top
Engine: SP383 FIRST Fuel Injection
Transmission: T56 Tremec Magnum
Axle/Gears: Moser 12 Bolt, 3.42 Eaton Posi
Someone broke into my car by using a screw driver and hammer and punching the lock cylinder out of the door. Now I have a door with a notch punched out of the metal and no way to replace the lock cylinder.
Anyone have any ideas? Could I weld up around the hole and grind it back to correct size, or would the heat be too much for a door skin? Replace the door skin? Replace the entire door?
Any advice is appreciated.
Damned thieves!!
Damned thieves!!
Car: 00 TA, 91 Formula, 89 RS
Same thing happened to my car. I plan on just replacing the door. I don't have any welding skills or anything...
You could probably go ahead and weld it, and clean up the hole. Eastwood sells a tool that crimps the cylinder hole depression (or flat if need be). Might give that a try. It's pretty cheap (<$20) IIRC..
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
