Heater Control Removal
Hi,
I need to replace my heater control in my 91 Camaro, and I found one in a 91 camaro at my local wrecking yard. The car there is pretty much all intact, was is the easiest way to remove the heater control?
I just don't want to spend all day removing the whole dash, and then find out I could have just done (this and this) to get it out..
I've had mine part way out, to change the bulbs before, but I don't see how you get behind it to loosen those connections? Remove the radio? remove the dash pad and go from the top?
Oh, not sure if it matters or not, but the car does not have A/C.
Chris.
Chris.
The_Phoenix
Feb 4, 2016 07:10 AM
